Old 12-02-2016, 10:08 PM
Rescue11's Avatar
Rescue11 Rescue11 is offline
Ok, well thanks for checking. I just really hope the P.O. didnt dick anything up??!
BTW, was this manufactured by Befco or Haban?
1- 1200 in pieces
1- 1864 in pieces
Old 12-16-2016, 10:09 PM
barkerwc4362 barkerwc4362 is offline
Default Front end weight
I use 8-42lb weights on the front of my Green 332 when I till with my yellow model 48 tiller. The yellow 48" model 48 tiller weighs around 450lbs. I can move it around using 4-42lbs on the front, but the other 4 are needed when tilling to keep the front end planted at all times. The 445 does indeed have a 540 rpm pto. I also believe the 540 pto turns in the opposite direction from the 2000 pto. The previous owner of my model 48 used it on a kubota, whose pto also rotated in the wrong direction. Luckily he did not use it much. Virtually no wear on the wrong sides of the tines. These heavy tillers can really make a nice seed bed in a hurry.
Bill
Old 12-16-2016, 10:13 PM
Rescue11's Avatar
Bill
How does it do with new gardens? Tilling through a grass yard...
Also, did you have to change the pto shafts? The 540 and 2k use different shafts correct?
1- 1200 in pieces
1- 1864 in pieces
