Old 12-14-2016, 09:06 AM
ab147's Avatar
ab147 ab147 is offline
Default Lift lever not working on 149
The lift lever on the 149 has a roll pin inside the tower that has fallen out, broke, anyway, it's gone, how can I repair this, looks like I'll need to remove the gas tank to access where the pin was. thanks
147 w/mower deck, plow and rototiller owned for 22 years
149 new to me in 2010
2 more 149's with a a42a snowblower new to me in 2011
Old 12-14-2016, 09:08 AM
Unless the hole is severely out of round you should just be able to install a new roll pin.
Old 12-14-2016, 09:26 AM
ab147's Avatar
"severely out of round" isn't the word for it. I took the lever out yesterday, What the shaft goes through I think would still hold a roll pin, but the hole in the lever is really messed up.
Old 12-14-2016, 06:32 PM
My advice is to either fix it or replace it to prevent future frustrations!......that is unless it isn't in the budget or you need it right away and we've all been there before.
Old 12-14-2016, 06:46 PM
ab147's Avatar
I've been working on my backup snowblower because we're supposed to get more snow on saturday. Going to work on the cub tomorrow. I'll put a new roll pin in it and see how it works.
Old 12-14-2016, 06:57 PM
Put a small wire through the pin to keep it from falling out.
Old 12-14-2016, 07:07 PM
ab147's Avatar
had to think for a minute what you were refering too, but yea, I'll do that. You'd think that the roll pin is supposed to stay in place.
Old 12-14-2016, 08:18 PM
My 149 has a ton of slop in the lift linkage, when it takes a dump it will get fixed by Mr. Miller the welder.
Old 12-14-2016, 10:19 PM
ab147's Avatar
I'm going to try a new roll pin, and if that doesn't work, I'll try the welder.
Old 12-14-2016, 11:20 PM
Rescue11's Avatar
Rescue11 Rescue11 is offline
Ever thought about welding the hole shut and drilling a new 1?
1- 1200 in pieces
1- 1864 in pieces
