Old 10-25-2016, 12:11 AM
johncub7172's Avatar
Howdy! I'm working on my 125 as time permits me. I really have a passion for these IH Cub Cadets! You can find my 125 thread in the main board of the forum.
You will see how much dirt and what not can collect around the pump over the years. A clean machine is a great preforming machine!!
Old 10-25-2016, 06:02 PM
charlie105's Avatar
charlie105 charlie105 is offline
Default hydro leak
Had a hydro fluid leak Last summer. could not track it down, Previously split the tractor.replaced the (105) cork gasket, trunion fixed,hydro housing cleaned,etc. To be sure I wasn't loosing a a significant amount of fluid, I checked the hydro level, and it FARTED about a pint of fluid out of the fill hole. I swear I filled it accurately……honest no kidding, would I lie ? Problem solved.
Old 10-26-2016, 09:10 AM
DoubleO7's Avatar
DoubleO7 DoubleO7 is offline
if the extra just flowed out that is no biggy.
but if it "farted out" with any force then maybe the vent needs to be cleaned out or off.
Old 10-31-2016, 05:45 PM
charlie105's Avatar
Default Hydro leak
About that vent,,,,,where is it, and how is it cleaned ?
Old 11-01-2016, 10:16 PM
AndrewNoyes AndrewNoyes is offline
On my 1650 the vent is a sintered or powedered metal bronze insert set flush into the top surface, above the fill port.
Old 11-01-2016, 10:28 PM
Willie, the expansion plug on mine was leaking also. It took me several times wiping things off with a rag, letting it sit overnight, checking with a light, touching to see where the wetness was, to narrow down the leak. But it definitely was the expansion plug, in my case. I think the PO had power washed it, and suspect that may have been too much.
It is an access cover for access to a nut retaining a gear in the transaxle. I carefully drilled thru the exact center, and tapped it 1/4-20. Then I found I had a small oil filter cup style wrench that fit over the hole (big side towards the plug). Then I took a long bolt and washer through the 1/2" drive hole, and used it as a puller to pull out the old plug. I carefully took an Exacto knife and cleaned the opening. A very small say, 1/16" bead of the oil resistant gasket maker, and then I tapped the new plug in. Be careful to only get it flat, and then stop. If it goes inside out, it will start getting loose again.
I hope this helps.
Andy
