Old 10-31-2016, 10:54 PM
tasnyder83 tasnyder83 is offline
Default 1650 frame alignment
I recently purchased a 1650 sight unseen. My main purpose was as a parts machine, but it runs fairly well. So, I am thinking about fixing it up rather than my 129, which isn't running. While looking it over this weekend, I noticed that the right side of the frame is about 1/4 to 3/8 of an inch higher than the left side. It is noticeable to the naked eye from the rear of the machine. I measured all down the frame tonight on a level surface and it is consistent from front to back, so I don't think the frame is twisted. I have never split a wide frame, so I am unfamiliar with the frame to differential setup. Is it possible that there is enough play in the bolt holes to create this much of a difference?
Old 10-31-2016, 10:58 PM
Shrewcub's Avatar
Shrewcub Shrewcub is offline
Did you check to make sure they are tight, first? All tires the same pressure?
Travis
1993 Cub Cadet 2064
1988 Cub Cadet 2072
1980 IH Cub Cadet 782 w/CH20
1966 IH Cub Cadet 102 w/K301
1961 IH Cub Cadet O
1967 IH Cub Cadet 102 & 122
JD 2155 w/ 175 loader
Old 10-31-2016, 11:00 PM
Might check to see if the bolts through the frame, axle tubes and into the rear end are there and not missing or broken off. Not an uncommon situation.
Old 10-31-2016, 11:19 PM
Haven't put a wrench to them yet. I'll check that when I can get to it. The tire pressure was the first thing I checked and corrected.
They all seem to be there, not sure of the tightness of them.
Thanks for the quick replies.
Tab
Old 10-31-2016, 11:51 PM
Dart1917 Dart1917 is offline
Are the tires a matched set? Check the overall height of the tires. To be that far off I would think the holes would have to be pretty worn on one side of the tractor.
Old 11-01-2016, 09:59 AM
johncub7172's Avatar
If any of the 6 mounting bolts are loose, they will wallow out the frame holes, which can't be good. I saved a nice 1450 from the scrap yard, that leaned heavy to the right. The "z" bracket was snapped. This bracket is a mount to the frame from the right front side of the transmission.
Posting any pictures help, and we'd love to see your 1450!
