yes both of mine are too...my neighbor said that they should be on the inside! All the pictures I have looked at the hinge is under it sooo.
The hinge should be between the headlight panel and the front casting.
If you look at the under side of the hood extension there is a provision for the hinge to fit into.
I saw that! The hinge that is on my 108 must have been replaced by the PO at some point cause it is about 3/4" above the nose casting when in place...I will have to trim it up a bit.
looking at your picture if my eyes aren't playing tricks on me since I have been up since 4am...your hinge is mounted on the inside of the headlight panel. I looked again at mine last evening and it is between the panel and the nose casting. As Yosemite Sam said there is a notch in the casting for the hinge. The PO of this 108 replaced the hinge at some point and it wasn't drilled right so when I put it back together I wasn't sure which was the correct way...the way mine is mounted now with a different hinge you can see the top part of the hinge when looking at the front of the tractor. I will have to trim it off some.
Ironman that is one nice looking 149 ya got there!!!!
| Thread Tools | |
| Display Modes | |
