I'm curious to Know what tractor those parts came off of.
it looks like the ps setup off a 1862 to me.
1782, 1862, 1440(sold), 89 1050, 128, 70, some run some don't! 72 scout IH 404 tractor |
FWIW,
I set my ps pump above the crossmember. I made a "C" bracket and bolted it to the bottom of the pump and bolted the bottom of fabbed bracket to the top of the cross member. I used column/pump from a 318 Deere. seems like the "C" bracket was less than 3" high. |
Just as a note, this thread is 3 years old.....
Opps, past my bedtime.
The new bracket you have is for a super and mounts to the side of the frame you need a bracket from a 1864that goes to the crossmember.I used one for a pattern and had to make one longer to drop my column from a super.The bracket I used mounts to the side of the frame
I wouldn't waste my time or money putting power steering on a cub, I put a set of Firestone tri ribs on my 1211 and I can steer it with my pinky finger. I also had deestone tri ribs on my 122 and it steered just as easy.
![]() I do have them (Firestone tri ribs) on the 1650, and it steers so much easier than any other front tires. BUT after using the 1872 with power steering, there is a big difference for us less "big muscular kinda guys"... ![]()
The bracket assembly that I made up works fine. My first design was close (needed to grind a bit to make room). The new bracket assembly has the modes for clearance. So this will let anyone to put power steering on any tractor that used the same mount as standard steering. (crossmember)
Power steering on a mounted snowblower is night and day and think about a loader tractor. Even cutting grass. ![]() From 129 to 782 plus can have power steering with a hydro setup.
Doug 126 Creeper,H lift,Deck, Sleeve hitch, B Plow, Weights 129 Deck, Blade, Weights 1200 Creeper Deck: 1250 B Tiller odd deck 782R with power steering ![]() ![]() ![]() ![]() ![]() JD 110H:JD 112H |
| Thread Tools | |
| Display Modes | |
