Old 08-06-2016, 05:12 PM
I hear yah 64fleetside...
Well today the postman brought a package from Jeff in pa,The shortened driveshaft.After cleaning the dirty balls and coupling parts,I found out I needed a fan,lucky for me I had one from the parts donor 1440.
Easy to install and it runs true as I am handsome.
Nice work Jeff.
Up to 534 and counting...
Old 08-06-2016, 05:13 PM
Good job, Lew!
Old 08-06-2016, 07:25 PM
Thank you sir,looking for your today's pickup soon!!!
Old 08-06-2016, 09:17 PM
Nice work Jeff.
Thank you Lew.
I checked runout before cutting, after pressing it together and after welding. My technique worked well.
Good to see it worked well
Jeff
Old 08-06-2016, 09:45 PM
Nice work Jeff and Lew. You guys make a good team.
Jeff did you spin it really slow in the lathe and weld it while it's in there? I saw a drive shaft guy make one the other day and he had his mig set up in a fixture that he just pulled the trigger while it spun and it was all set
Old 08-06-2016, 10:06 PM
No, I drilled and reamed a hole in one side and the other side was press fit "pin" ( 3X diameter to length ) . I welded the root pass and then checked runout on the lathe. After verifying it was good, I finish welding it.
Rechecked runout and then I turned the weld OD to shaft size.
Old 08-06-2016, 11:32 PM
Good work gentlemen.
Old 08-16-2016, 06:34 PM
Put the finishing touches on the 1541 today,headlight rings came yesterday, side panels on and polished up.
That Mothers does the trick!
Old 08-16-2016, 06:53 PM
I'm impressed, I'll keep you in mind for those custom drive shaft lengths.
Old 08-16-2016, 09:42 PM
The 1541 is looking good, Lew!
