I'm impressed. The blades should work as long as you keep them out of the dirt and rocks. Dado blades are another possibility.
Thanks guys. I'll try to get video proof of it's success or failure. I plan on digging out around to stumps to clear away the dirt and possible rocks.
I did a little test cut on a 2x8 until it caught traction and the board moved. ![]()
Adam 1964 Model 100 w/ K301 12hp and custom hydraulics 1972 Model 149 turned 129 w/ K301 12hp, triple hydraulics, 66 series clone |
We shall call it "the beaver".
Roto-beaver?
Looks cool!
when you wear those out, you should build something using an automotive flywheel and add the teeth, so it does't slow down as easily. that's how most stump grinders are.
1782, 1862, 1440(sold), 89 1050, 128, 70, some run some don't! 72 scout IH 404 tractor |
Looks like it should do the job.
Good job as always, Adam!
| Thread Tools | |
| Display Modes | |
