Old 05-31-2016, 07:00 PM
Userj8670's Avatar
Default Mower deck help
Been brought to my attention that the middle spindle on my mower deck is shot- but I was also informed they don't make them any more? Does this hold true? What are my options?
Thanks guys!
Old 05-31-2016, 07:06 PM
It is impossible to answer your question until we know the Model Number of your Mower Deck.
Old 05-31-2016, 07:23 PM
ironman's Avatar
ironman ironman is online now
Thanks guys!
It is true, they don't make the mower deck any more!
Old 05-31-2016, 09:08 PM
Green stripe wide frame's Avatar
Green stripe wide frame Green stripe wide frame is offline
Funny
102 soon to be tiller machine
108 mower
73 plow machine
169 soon to be mower
122x2 now parts machines
Parts 129
149 parts
61 "O"
104 job to be determined
Old 05-31-2016, 10:25 PM
Userj8670's Avatar
Sorry for the lack of info fellas. I am not sure of the model number but it's the orig 42 inch deck off my '71 126. Hope that helps.
Old 05-31-2016, 10:38 PM
I think we need to know what the definition of "shot" is and which style of spindle it is, replaceable bearings or water pump style bearing.
Old 05-31-2016, 10:55 PM
If you don't know, the newer style has tapered bearings like old style vehicle front wheel bearings in an aluminum housing.
Old 05-31-2016, 10:56 PM
So, the tag is gone?
A picture is worth a shot...
Old 06-01-2016, 07:53 AM
samiam44 samiam44 is offline
Bearings are available . Old style was a st-745.
New style as stated ad can get at auto parts store.
Take it apart and see which brg you have and if the housings are serviceable. The st-745 is available aftermarket- I think the best price is around $65/each. The replacement assemblies are ~ $155 each new. Both ways you can find used also. The tensioner idler pulley can be rough, the idler arm usually is ungreased even though there is a provision for a zerk. Spring and bolt might need replacement.
I've got mine apart right now. My deck looked quite clean and there were no play in the bearings. I had a bad idler and one bearing was a little rough. Took it a part and broke a second bearing. So rebuilding the idler arm, new idler pulley, bolts/nuts. I haven't decided on new st-745 bearings or new assemblies which are 2x the cost. Either way, the parts are getting a true epoxy primer and sealed to prevent corrosion. Pulleys have a bit of wear- lots of deep rust pits, but I presume if they are still solid- they will work.
M
Old 06-03-2016, 05:50 PM
Userj8670's Avatar
So here are some pix. The center pulley is shot as the welds and bearing are toast and I believe that is one assembly. Additionally there's a stack of bearings under that I will need to replace as well. Attached in the diagram pic I need parts 23,29 & 17,18,19,20,30,31. Hope this helps?
