Old 05-14-2016, 09:38 PM
johncub7172's Avatar
Originally Posted by prlwpod View Post
Greetings- Before I do any irreparable damage to the PTO, what is the recommended method for removing the three (or more) set screws. I've thus far blasted them with brake parts cleaner followed by 120 PSI through the air nozzle just to remove the excess debris. Then sprayed and soaked each one with Kroil, and that's where I've stopped. My concern is that if the hex is slighly worn or stripped , I don't want to make it any worse. What method/s do you use to extract the hex head screws? Thanks, Paul in Providence
I too, work as a machinist to a large degree. The most important part is having the set screw head super clean. Use a straight pick to dig out the crud, following all advice and tips shared to assure its clean so your wrench as the best chance for bite as it can. In many cases, this is how the screw could get rounded out.
Old 05-15-2016, 09:37 AM
prlwpod prlwpod is offline
Default A .22 caliber bore brush!
What a fantastic idea! I've been using a similar tool for years from my other "hobby", vacuum tube electronics. It's a hand held cylindrical brush made for cleaning the contacts of a vacuum tube socket , however it's not nearly as robust as a bore brush. I wish that someone still made an assortment of these style brushes. Just for the record, what is the size and thread pitch of these little set screws? Thank you, Paul
Old 05-15-2016, 12:12 PM
SLS327 SLS327 is offline
1/4 - 20 the inner three need to have a point, the outer three need to be flat, I was just at the hardware store yesterday.
Steven
__________________________________________
127 NF, spring assist, 36" IH Danco BB-36 snowthrower, 42" mower deck. CW-36 snowthrower, 42" NF blade. QA42A blower, 126,127,149,1720.
Old 05-15-2016, 02:08 PM
RLause's Avatar
RLause RLause is offline
Use a bottom tap or an old tap with the lead ground off to clean the threads above the screws.
Richard
Old 05-15-2016, 02:39 PM
Saw a video of a guy who got the hub red hot where the screws were and said they would drill much easier after that. Not sure if the temper gets taken out of them but I was going to try it one time as drilling them is beyond words as most know.
Jeff what do you think of that? I'm thinking the hub might warp with such heat from a Rose bud but maybe not.
Old 05-15-2016, 02:49 PM
Nailhead Nailhead is offline
That's interesting-- the set I got loose had the pointed one on top. I didn't remove the lower one, so I don't know what it looks like.
1965 122 with no bells or whistles, other than a spiffy restored 42" CI deck.
Old 05-15-2016, 07:25 PM
Localized heating at the set screw location would probably be fine. My main concern would be trying to face it afterwards because if it cools too fast, it becomes hard. ( difficult to machine)
Old 05-16-2016, 01:35 AM
Berwil's Avatar
Berwil Berwil is offline
I'm not sure if this is applicable, but I have spot annealed case hardened shaft to drill through it. I took a scrap piece of round stock the diameter of the desired hole, heated the end to red hot and held it to the shaft where I wanted the hole. Maybe you could try the same thing with the set screw and a piece of 3/16" rod. Heat the rod, stick it in the end of the set screw and let it transfer it's heat and anneal the screw. With all the mass around the screw it may take a few heating attempts to get the screw warm enough to anneal, but it should keep you from overheating the rest of the pto.
Bill
Old 05-16-2016, 02:12 AM
Bill
It's worth a try, maybe it'll save this project.
