Since we have a thread about what you did with your cub today I thought I'd start a thread about what you did to your cub today.
I worked on getting the engine mounted in the 1282 and when I got home my son wanted to play outside so while he ran around I spent some time polishing the 108 and 1211 so they look top notch for plow day Saturday.
I had some time this morning so I pulled a troublesome ignition out of my 149 and ordered a replacement from one of our sponsors.
Changed oil and sharpened the blades on my 2072. Also greased it, changed air filter and gauged the tires. Tightned the alum block on the side of the engine where the lines for the remote filter hook up--hopefully this is was the cause of my oil leak.
Put new coil,condenser,points,and plug wire on the 100.
Took the non-IH exaust pipe off the 982 and prepped the orgional pipes and shields for paint. Took the plow off the 782 cause it was taking up too much room.
I changed a front light on the 1512,
Though it would be a bright idea!
I walked by them in the garage, hauled off an old water softener! Lol
Brian April 1979 1200 Quietline 44A deck 1988 1211 customized into a 1288 with a K301AQS 38C deck and a 1864 54” deck . Snow blades 42" and 54" . Brinly disk, brinly plow a cultivator and a $5 brinly yard rake! ![]() |
I got my new original running.
Got a new exhaust and deck belt, still running great, but then again, when doesn't a cub run great?
Burned some diesel fuel with it, mowing grass!
I worked at removing the hot rod flames off the side panels of the 1050. Ordered trunion springs and a hydro line for the 1862 I have stripped down.
Cub Cadet 1811 undergoing restoration Cub Cadet 1862 waiting for paint Cub Cadet 1050 finally got all the parts bought so next in line behind the 1811 for restoration Allis Chalmers 416 Massey Ferguson MF-8 Brinly 10"plow Soil Mover garden tractor dirt scraper Taking donations for a new bigger garage to hold them all ![]() |
Thread Tools | |
Display Modes | |
