Old 03-16-2016, 06:18 AM
BigB87's Avatar
BigB87 BigB87 is offline
Default Need info
It is possible to check the v/r for a s/g tractor without having it running? Like ohming it out? Also sorry for being gone for a while guys...work has been busy plus I've had some projects to finish up
Brandon
CC models: 86, 100 w/hanban sickle mower & 1872
1972 86 w/12" brinly plow & 65lb wheel weights & 42" grader blade
1965 100 w/hanban sickle mower
1989CCC 1872 w/50c mower
Old 03-16-2016, 08:49 AM
YES and NO.
You can check resistances IF....you have the specifications to compare to. To check amperage and voltage, you need a functional charging system.
Old 03-16-2016, 09:13 AM
Is there a reason you need to test it without the tractor running?
Old 03-16-2016, 09:24 AM
BigB87's Avatar
Just got a newer s/g yesterday. Have a V / R off another tractor but cant remember if its good or bad
Brandon
Old 03-16-2016, 09:26 AM
In that case I would go ahead and install it and see what happens.
Old 03-16-2016, 09:38 AM
BigB87's Avatar
Kinda iffy too. My last one burnt up.
Brandon
