#31
1989 - Cub Cadet 1772 1987 - Cub Cadet 1572 w/Rear PTO & Cat. 0 38" Lawn Sweeper #196483 42" L42 (Bush Hog) Rotary Cutter # 190349 45" 2-Stage Snowblower # 196364 48" Haban Rotortiller Rear PTO Driven #190356 54" SnowBlade with hydraulic Angle #196376 60" Haban Mowing Deck #196374 |
#32
Today's parts haul;
![]() As I have said before, mine would not crank using the key. Some of the reading I had done here, indicated a faulty ignition switch. $25.00 at the local Kubota dealer. ![]() Problem is, after installing it, the engine still would not crank using the key? So I did some wire chasing with the volt ohm meter. That lead me to this relay; ![]() A quick trip to the parts store, I installed the new one, viola! It cranks with the key. Then I mounted this; on the air cleaner bracket. Ran some 8 gauge wire, just have to finish running the couple wires. I went ahead and installed these; Still need to deal with the high idle. Pretty productive day. Won't be long and I'll be mowing with it. I appreciate all of the help, you guys have been invaluable, in getting this far. |
#34
High - idle? I had that on my 1772 when I got it. I disconnected the throttle cable at the injector pump, then started it to see if I could get a normal idle. I had a couple things wrong with it but mainly the cable was mis-adjusted in the clamp at the injector.
#35
I installed the new ignition switch (because the tractor would not crank, had to jump the solenoid to start it) then the new glow plugs, retested the voltage at the glow plugs. Guess what, they showed 12v? Sooooooo I either messed up my first readings, or something about the new glow plugs / ignition switch enable higher voltage at the glow plugs. No change to my dash board light, still lights up, while holding the key to the left. I still plan to complete the glow plug relay install, because it just makes more sense, to load the glow plugs off of the battery / relay versus the ignition switch. Quote:
![]() I was messing with that last night, my throttle lever has too much play in it, not sure if that is related to it being retrofitted with the separate shut off knob? But definitely more work to do there. |
#36
As a side note, I went to my local New Holland / Kubota dealer to get the switch and glow plugs.
The parts counter guy was an older gentleman. He wanted to know what Kubota tractor I was working on, he was very dubious that I just walked in with part number for individual parts. I told him I was working on a Cub Cadet with a Kubota motor in it. he went on and on about how Cub Cadet never put a Kubota motor in a garden tractor! Once I convinced him it was a real thing, he says well that thing will run forever! Those little engines go for thousands and thousands of hours! Funny interaction. |
#37
Both the Y-103V or the Y-702R glow plug will work. Below is some info I gathered from both the NGK website and pricing is from Amazon. As you can see, like everything else you get what you pay for.
Y-103V - Heats to 800° C in 15-17 sec. $8.39 ea Y-702R - Heats to 900° C in approx. 6 sec. $21.34 ea
1450 w/ 44gt deck, 1572 w/ 50C deck, 450 snowblower. |
#38
I run the Y-103V's in all of my machines along with the solenoid upgrade.
#39
#40
| Thread Tools | |
| Display Modes | |
