What is the best way to remove the old decals and adhesive from the side panels on an 1862?
Heat gun to get the decals off and rubbing alcohal to remove the adhesive, its a slow process but it won't damage the paint.
Until I bought a remover tool I used a heat gun or hair dryer then cleaned it up with Glue remover or lacquer thinner. This is on metal bodies not plastic. I would think the same would work on the plastic but not use too much heat.
Cub Cadet 1811 undergoing restoration Cub Cadet 1862 waiting for paint Cub Cadet 1050 finally got all the parts bought so next in line behind the 1811 for restoration Allis Chalmers 416 Massey Ferguson MF-8 Brinly 10"plow Soil Mover garden tractor dirt scraper Taking donations for a new bigger garage to hold them all
The glue remover we used was a 3m product sold at NAPA. We now use a slow speed pneumatic grinder that uses a rubber wheel to take them off. Best tool ever! NAPA sells the same type wheels to use in a drill but you have to use a slow speed.
I use a heat gun and prep-sol
You could try wd-40, not good for much else! Lol
Brian April 1979 1200 Quietline 44A deck 1988 1211 customized into a 1288 with a K301AQS 38C deck and a 1864 54” deck . Snow blades 42" and 54" . Brinly disk, brinly plow a cultivator and a $5 brinly yard rake!
I took the decals off the hood of my 1864 due to them peeling off somewhat on their own. I used a mixture of vegetable oil and baking soda, simply mix them together in a jar and it becomes a paste. Rub the paste on the adhesive and allow to sit overnight. Worked well, you may have to apply more than once and it didn't seem to harm the plastic.
Nathan Gardners, PA Cub Cadet Yanmar SC2400
Heat gun and Goop glue remover.
Tankman '95 CCC 1641 Eastern PA USMC |
Just removed a brand new decal from a JD 318 because I was too lazy to go and get a little dishwasher soap when I put it on. Glue stuck like crazy but hot air heat gun and a little patience did the trick. I then used a little paint thinner and the glue came right off.
1811 Hydro "Failing to prepare is preparing to fail".
| Thread Tools | |
| Display Modes | |
