The 5 prong switch is marked with letters on back. B G L S M. I have to hook up my orange safety switch wire, my green ground going to solenoid and my black wire that goes to coil. Just don't know where wires go on what prongs? Any help guys would be appreciated!
THANKS! |
And also this is how I've got my voltage regulator hooked up. Hope it's right? I don't think it's the original one though? The gray middle wire is hooked to an BAT prong, the top yellow wire is hooked to an L prong and the blue wire is hooked to an unmarked prong on back of regulator? And Pink wire is ground.
I would use the correct one, especially if you have a new voltage regulator. That one is for a magneto ignition.
Ok, that's what I will do. Order one tomorrow.
The yellow wire should be on the f terminal not the l terminal
I was wrong, yellow wire IS hooked to top F terminal. So should the blue wire hooked to unmarked terminal in back be hooked to bottom L terminal?
The one on back is the G terminal.
Ok thanks. So I guess u can't use a 5 prong ignition switch at all?
| Thread Tools | |
| Display Modes | |
