Old 06-05-2015, 02:07 PM
zimm17's Avatar
zimm17 zimm17 is offline
Default Kirk engines Heavy duty tie rod ends?
Anyone upgrade tie rod ends? I'm going to replace them anyways, and this kit is the same price as stock...
http://www.kirkengines.com/index.php...ngTieRodEndKit
1973 Cub Cadet 149
2023 John Deere X590
Farmall B sitting in relative's barn
Old 06-05-2015, 02:16 PM
jimbob200521's Avatar
Good kit, should do you good. Also an option is from there guys, highly recommended:
http://www.mcmaster.com/
Look up your tie rod ends/size and order from there. They have the same thing Kirk Engines has except greaseable. It's what I order whenever I replace them on my machines. It's nice being able to grease them.
-Ryan
Old 06-05-2015, 02:20 PM
They look awfully short!!
You will only have about 3 threads screwed in on each end of the tie rod.
At least that's what I have ran into when replacing ends on several of my machines. The older OEM pieces were about 3/8" longer.
Only option I can see is to lengthen the rod some.
Barely enough thread to get the correct toe in.
Old 06-05-2015, 02:22 PM
zimm17's Avatar
What about these guys? And are all 4 RH threads on a 149?
http://www.mcmaster.com/#4444t931/=xhs34n
1973 Cub Cadet 149
Old 06-05-2015, 02:27 PM
zimm17's Avatar
These are longer at 2 1/8" eye to end. The others are 1 5/8". I'll have to measure the old ones when I get home.
http://www.mcmaster.com/#6960t71/=xhs6dn
1973 Cub Cadet 149
Old 06-05-2015, 03:00 PM
IHCadetCollector's Avatar
IHCadetCollector IHCadetCollector is offline
I have a set of those heim joints on my 1200. They seem to be lasting much longer than the regular ball joints. I reccomend you get some with grease fittings though.
I lost track of what I own a long time ago!
Old 06-05-2015, 03:24 PM
Group_44's Avatar
Group_44 Group_44 is offline
I put the McMaster rod ends on all my Cyclops Supers and my 1864, they fit and are much more durable, cheaper too. They have them in stock and the shipping is fast. Take a look at this thread it shows the original style vs. the ones from McMaster Carr.
http://www.onlycubcadets.net/forum/s...power+steering
2082 w/60" Haban Deck & 450 Blower,AGs,weights
2084 w/54" Deck & 451 Blower
2086 w/54" Deck, 54" Haban Snow Blade
1864 w/54" Deck and weights
1641 w/48" Deck
1650 w/44" Deck parts Tractor (getting smaller all the time)
445 John Deere w/ model 40 FEL (went over to the dark side)
Old 06-06-2015, 07:58 AM
nikster's Avatar
nikster nikster is offline
Yup, I liked the idea of grease on them. A few years back I replaced them on my # 1250, really improved steering.
Nik
