Old 05-03-2009, 06:02 PM
elevenpoint's Avatar
elevenpoint elevenpoint is offline
Default 104 running fine
The 104 that I found sitting outside for years was in bad shape when I got to looking at it this morning......fixed the battery cables, flush tank, muddobber nest in the intake valve area,put carb on from the 126, sediment bowl, fuel lines, battery, plug wire, and fresh fuel..........started right away and runs and idles like new. One problem though, the clutch is stuck together, how do I get it working again?
Old 05-03-2009, 09:55 PM
First thing I do when I get one with a stuck clutch is to hold the pedal down and put a large screw driver between the disk and the plate and try to pop them apart, sometimes it works and sometimes it doesn't. I have had a lot more of them pop loose than ones that didn't.
Glad to hear that things are going well so far.
Old 05-03-2009, 10:07 PM
Congrats, on getting your 104 going elevenpoint!
Old 05-03-2009, 10:22 PM
CBH's Avatar
CBH CBH is offline
Be careful trying to force the clutch pieces apart. The discs can sometimes be very brittle and break easily.
Old 05-04-2009, 06:20 AM
Default PB Blaster
I did get it apart with hammer and screwdriver and it is working, although the disc did get abused during the process it has probably been rusted together for years.
Old 05-04-2009, 06:53 AM
RPalmer's Avatar
RPalmer RPalmer is offline
Congratulations on a great find.
