Old 05-05-2015, 12:25 PM
782CC 782CC is offline
Default Should I mod or leave 3pt alone
This 2082 I picked up, has the factory small top link mount. The top link like most of the machine has seen better days. I want some input from you guys. Should I cut off the top link mount and make a new one so both ends are the same size? Also would add more positions while doing it. The Ruegg on the 2072 is the larger style so top links would swap. Also, I may not keep the 2082 so not sure if I am helping or hurting value to change it. I can toss up a pic later if it helps.
Old 05-05-2015, 12:27 PM
That would be great.
Old 05-05-2015, 03:28 PM
First pic is the 2082 I might modify. The second is the Ruegg 3pt on my 2072. Third and fourth I have the top link for the 2072 beside it to show the difference in size. Implement end is the same size on both 3pts. It is only the machine side that is different. I should have put a pin in to show it is 1/2 inch vs 5.8 pin as well as width.
Old 05-05-2015, 04:25 PM
http://www.xtrememotorworks.com/Part...03%20Point.htm
Scroll down to the 19th item
Old 05-05-2015, 07:18 PM
gsomersjr's Avatar
gsomersjr gsomersjr is offline
I wouldn't worry about affecting the value. It's just a garden tractor. Do whatever suits you best while you're using it.
Current: 102 122 SZ60
Past: Original 71 72 73 86 100 102 122 123 124 125 127 129 147 149 169 383 582 682 782 782D 784 982 1000 1050 1100 1200 1204 1210 1250 1282 1415 1420 1440 1450 1535 1541 1641 1650 1710 1711 1730 1806 1810 1811 1860 1861 1862 1863 1864 1882 3185 3200 3205 7265
Old 05-06-2015, 07:46 AM
DoubleO7's Avatar
DoubleO7 DoubleO7 is offline
The bigger, beefier stuff should be on the tractor with the bigger model number.
Old 05-06-2015, 11:25 AM
Well that settles it. lol
Sam - I had a really hard time counting to 19. geesh. That looks like my answer and probably going to modify both machines.
Thanks guys
