Old 06-13-2010, 10:43 AM
d_day2613's Avatar
d_day2613 d_day2613 is offline
Default Hydro relief valves
Can anyone tell me if you can put manual reliefs in place of auto reliefs? If so, is anything affected? I can only assume that using the mauals in place of the autos would just make it so you couldn't push the tractor. Any help will be greatly appreciated!!!
Old 06-13-2010, 10:55 AM
Yes, they are interchangeable. If I had the auto ones, I'd keep them over the manual valves. You are correct on not being able to push the tractor, unless you have the lever on the right side of the tunnel cover. When you use the lever, it has a tab that pushes the pins down on the manual valves. Then you can push your tractor. When I had my 1250, I replaced the manual valves with the automatic ones. Hope this helps.
Old 06-13-2010, 12:35 PM
Amigatec's Avatar
Amigatec Amigatec is offline
You can still push it, just grab a fender and pick it up enough to get the wheel off the ground, you can push it that way.
Pat Benner Haskell OK
