Old 04-28-2009, 11:10 PM
wig wig is offline
Default Kohler KT 17 Timing
I have the manual but not completely clear on setting the timing. The motor is out of tractor with side covers off and I want to set the points right. Since I have not ran it yet I will not be using the timing light method. I have found the TDC and S mark on the flywheel and located the roll pin on #1 side of engine.The manual says when the points begin to open the the "S" mark on flywheel should be opposite of the roll pin. What do they mean.?Do they mean just past the roll pin or 180 degrees from the roll pin?This is the method I want to use.
Old 04-30-2009, 10:18 AM
I'll take a look at a junk engine I have today and see if I can answer this for you. I agree that the manual is unclear. Make sure you use a continuity tester or ohmmeter for this, as you can't see the points starting to open.
Old 04-30-2009, 04:55 PM
I looked at one of my blown motors today, and I think what they mean is that the timing mark should be behind the roll pin when viewed through the sight hole in the blower housing. If it was 180 degrees from the roll pin, you wouldn't really be able to tell anyway...
Old 04-30-2009, 05:19 PM
RPalmer's Avatar
RPalmer RPalmer is offline
I don't know about tractors with side covers, but if you have points... I turn the engine by hand until the points are at their widest gap. Double check that the points pin is secure when pushed in toward the engine and the set to the proper gap. Mine is .020. With that method the engine fired "right" up even though it needed a carb rebuild at the time. Have fun.
Old 04-30-2009, 07:00 PM
JMD JMD is offline
Default Point Gap
You can set the point gap or you can set the timing. Set the timing. IF you set gap after or before timing it will change the timing. IF the timing is right the gap is right.
Old 04-30-2009, 07:39 PM
JMD JMD is offline
Thumbs up Point Gap
The above statement assuming you are working with new parts. Timing is the most important thing.
Old 04-30-2009, 08:01 PM
RPalmer's Avatar
I guess I missed the timing. Gap will change timing. Timing will not change gap. I also thought timing was set at the cam and not adjustable without resetting the cam.
Old 04-30-2009, 08:59 PM
JMD JMD is offline
Smile Timing
When you set the timing the gap has to be right they are connected. When you have the timing set the points will fire plug, If you check point gap after you set timing and find you have slightly more or less then the recommend clearence adjusting the gap will change the timing you could play this game all day long. Set the timing the gap will be right.
Old 04-30-2009, 09:49 PM
wig wig is offline
Default Timing
You have me confused now! Correct me if wrong. The points gap is all there is to adjust. So, what do you mean by setting the timing and then the gap or vise versa?The engine is not running yet or even in the tractor so setting the timing is out of the question.I thought you set the points and that was it. So if I am wrong then how do you adjust the timing (set)?What is the best way with it not running yet to set the points?
Old 04-30-2009, 10:25 PM
RPalmer's Avatar
We are talking about two different animals which get loosely called timing. First and always first is engine timing. Basically this is the synchronization of the valve train to the cylinders. That is to say that the valves are in the correct position in relation ship to the piston and cycle the engine is in. Intake, compression,power,exhaust. The second animal is ignition timing. This is the timing of the spark so that you get spark on time in relationship to where the piston is for an optimum burn and power.
Engine timing should never be a concern unless you make a repair to the inside of your engine (sorta, heads don't count). The only maintenance timing done is to the ignition. This is where your point gap comes into play.
There that ought to keep you confused a while longer.
