Old 05-23-2010, 03:52 PM
TEET's Avatar
TEET TEET is offline
Make sure you save the adjustable carbs off all of those blown Series Is.
Why is that Matt...do they have other applications?
I have a complete intake, carb, air cleaner assembly from my blown KT17...kinda figured it was only good for a boat anchor....
Jeff (teet)
CCC 1211
71
127
102
122
1962 Original
Old 05-23-2010, 06:57 PM
The adjustable carbs are good for replacing the POS Walbro non-adjustable carbs on the M18 engines. You can also use the jugs, heads, and sheetmetal on the Magnum twins. I usually keep all of that stuff when I junk a blown KT-17 because of the carbs and because sheetmetal disappears for some reason...people take it off and are too lazy to put it back on or something. I wouldn't junk the air cleaners either...they fit the M18s (air cleaner assemblies come up missing once in awhile), will also fit K-series singles with slight mods.
Old 05-23-2010, 11:03 PM
If I had that sweet little 682 this is what I'd do with it
http://www.smallenginewarehouse.com/...N=356447-IH682
Old 05-24-2010, 11:11 AM
midyearguru midyearguru is offline
I guess the smart thing for me to do is get an adjustable carb for my 1872. Anybody got one for sale?
Old 05-24-2010, 04:17 PM
Matt,
Yeah, I will keep them. I probably keep more stuff then I need to most of the time!
Thanks Allen, Teet, and Sam Mac!
Old 05-25-2010, 03:47 PM
jbollis's Avatar
jbollis jbollis is offline
Matt,
Are the jugs and heads the same, or is there some work to be done in order for them to work? And what is involved in the carb swap ?
Thanks JOE
Sold everything but one.
Old 05-25-2010, 06:30 PM
The jugs are the same from what I've heard...however, you must use gaskets between the jugs and the block on jugs that had gaskets there, and RTV on jugs that had RTV there...that is the difference. The heads might be slightly lower compression (that's how they bumped the KT-17 up to 18 hp when they made it into the M18), but they will work. All you have to do for the carb swap is bolt it on and go. Some carbs need the hole in the throttle arm enlarged to fit the linkage design on some of the later engines.
Old 05-27-2010, 04:24 PM
JeffD JeffD is offline
Buy another blown KT17, build 1 from the 2, and install a set of 18hp rods in it, and it will be good to go. My Dad has been doing that for years.
Jeff
782 w/Honda power
129 stock for now...
100 basketcase
Old 05-27-2010, 06:07 PM
Jeff
I assume he's drilling the rod caps for oil holes, right? You can't use Magnum rods on a series I unless you do that. It'll seize up pretty fast otherwise. I had one engine that someone did that to, and didn't put oil holes in the rods.
Old 05-27-2010, 09:14 PM
That is correct Matt.
Jeff
782 w/Honda power
100 basketcase
