Old 12-18-2014, 11:25 AM
Originally Posted by garnold View Post
Now referring back to J-Mech's reply about this being alum is my idea ok or would this approach put to much stress on these alum threaded screw holes?
I don't think as long as you don't get stupid that is fine. You run more of a risk of breaking the hub than pulling the threads.
Here's the issue I see with the whole puller thing....
The hub isn't stuck in the center, it's stuck on the dowel which is off center to one side. When you use a puller, the force is in the center, but it will be pulling to one side because that's where it's stuck. It will "cock" while pulling and you could break the hub. I've never had one so stuck that I couldn't get it off with a little bit of working. I think Y-Sam's approach combined with some heat like Sam suggested is the best approach. Really, don't make this harder than it really is. I was thinking I broke one one time. But IIRC, it was really corroded and brittle from age and deterioration.
Old 12-18-2014, 11:30 AM
garnold's Avatar
garnold garnold is offline
Good deal then. I'll do some tapping tonight on it and if that does not work snag a torch from a friend to apply some heat.
108 upgraded to 12hp
127 with all the trimmings
73 WIP
75 WIP
Blade, blower, decks
Tons of left over parts
Old 12-18-2014, 11:32 AM
On another note, put anti-seize or grease on the dowel when you reinstall it. That way next time it comes right off.
Old 12-18-2014, 12:04 PM
garnold's Avatar
Good advice
73 WIP
75 WIP
Old 12-19-2014, 10:30 PM
garnold's Avatar
Man this worked out great! I used my air hammer and just put a bit in it that we talked about a long time about to push out spirol pins. It's the bit with that nip on the tip just like the correct punch to use to push out those PITA pins. So I just hammered the drive shaft a little and pulled the thing off by hand! OMG, few things I've done so far have actually worked this perfect. I mean this just worked great and was safe on the hub. Just like you folks said, the hub was stuck solid inside the fly wheel. Cool part was that came off at the same time! Nice win for the rookie I have to say.
73 WIP
75 WIP
Old 12-19-2014, 10:43 PM
Ok. I'm impressed. I didn't even think to try that, Gene. Good call!
Don't let that go to your head, your still a rookie. LMFAO!!!
Old 12-20-2014, 05:03 PM
Glad you got it off Gene.
Old 12-20-2014, 06:57 PM
a3v03v0's Avatar
a3v03v0 a3v03v0 is offline
Glad it worked for you.
I have been using an air hammer/chisel on flywheels and pump rotors for about a year now. Slick.
Old 12-20-2014, 07:07 PM
works great removing steering wheels too!!!
Up to 530 and counting...
Old 12-20-2014, 08:43 PM
X2, only way to go
