And I plan to use the one I bought shortly :-)
108 upgraded to 12hp 127 with all the trimmings 73 WIP 75 WIP Blade, blower, decks Tons of left over parts ![]() |
![]() Quote:
now how about this bearing. I read that I need to hit this inner part clock wise to loosen it but it does not seem to have to place to hit that I have seen in other pics.
Look at my picture with the hand drill in it. Behind the bearing at about 11:00 is a shallow hole. That is what you hit with a punch to get the eccentric loose.
![]() Quote:
129 cub cadet. Removal of clutch bearing and star…: http://youtu.be/mODDDUdxgdk
Got ya. Thank you :-)
There was a set screw in this collar that I removed with a nut on it. I took that out because I think that also held the collar in place. Now I hit with a punch using that small hole as a target CCW correct? It's not moving so I just want to know if I can/should really give it a good whack. It's getting late here at the Cub repair shop which happens to be my garage directly under my daughter's bedroom so I'll have to hold off on the procedure till tomorrow.
![]() Quote:
Yeah, that hole is there and is the one I was using to hit but was not sure how hard I can hit. Seems like the metal is already getting a little beat up and I have not gotten it to budge yet.
![]() Quote:
Hit it!! BFH! |
Thread Tools | |
Display Modes | |
