the 1450 I got for $150 with snow blower I am in south center Michigan
A 1450 was my first Cub Cadet and I love it. Plenty of power for the 50" deck and good handling all around tractor. Some elbow grease and a few dollars and you'll have a good machine.
782D, 1450, 100, SO 76, 60, 102 puller, 3314 self propelled and 3323 push w electric start |
Or if you want to part it out i would buy the rearend pump, lines lift cylinder spool valve and lever??? Or how much would you want for the whole thing, IF you decided to part with it???
2030660U560195*
according to some charts ive seen it puts it at a build date somewhere around July of '75. |
as for selling it, thats the overall plan as of now. i want to give it a chance to live again before i cut it apart though. as for pricing i havent a clue what they are worth, im a gravely guy, i know gravely prices. i might get it running and use it as a tractor show runner being a quiet line it may be quieter than a gravely and not disturb as many kids ![]()
http://www.oreillyauto.com/site/c/de...keyword=+k5252
can these be used as ISO mounts? they are the same as the MOOG ones ive seen being used in place of the factory. and they are quite a bit cheaper than factory too. i dont want to put a lot of money into it until i know it runs, and i dont want to destroy anything because the engines loose. |
http://www.onlycubcadets.net/forum/s...ad.php?t=20875
-Ryan
im going to see if this tractor will start here soon. i want to know if it will run before i put too much into it. now, some if not all of the engine mount bolts are gone, you can slide the engine around with no effort. is there a grounding cable for the engine, or does it use these bolts as an engine ground? i had an old rubber mounted honda that had a grounding cable that rusted off and it grounded through the throttle cable and welded it together on the next hit of the key. i dont want that issue. the oil is clean and full. ive got to see if its got compression. looking in the spark plug hole i know the valves move. it was dark in there so i didnt see the piston, but i got my trusty flashlight some new batteries. ill run it with some carb/choke cleaner so i dont have to pull the carb and clean it to run. ill do that when i know it runs. if i get it running i may decide to keep it, see if it fights with my gravelys. so far it has one flat tire, the gravely might cause more with some yellow moving in...
| Thread Tools | |
| Display Modes | |
