I horse traded for a set of 4.80x4 rims for Carson's tractor and didn't notice until I got home that 1 has bearings inside and the other looks to use bushings. It has a 1 inch hole or bigger. Since I want to put 3/4 spindles on,and use tri ribs,can I buy the bushing? Maybe someone has one for sale. What are my options? These are really rust free and I'd like to use them..
Pat Harmon Loganton,Pa 128 Cub Cadet 1200 Cub cadet (Red) LT 1042 Cub Cadet 1200 Cub Cadet 165 Hydro John Deere 1941 John Deere H 1950 David Bradley 5756 1952 David Bradley 57561 Super Power |
The CCO was the only model that used "bushings" in the front Rims. From the 70/100 Series and newer, ball bearings were used.
Are new bushings available? Or should I have one made for me? Maybe I could even swap even up if someone needs a nice rim..
Pat,Go to CC specialties and look under the wheel & tire section and their listed brand new for $9.00ea.
Good Luck,Bruce |
Pat if you want to change to 3/4" spindles just swap out the bushings for 3/4 bearings you can pick them up from your local cub dealer. They aren't cheap but work much better than bushings. I believe the bushings have a 7/8" hole, and I believe the bearings are 3/4" hole with a 1 3/8" od. I have the bearing part number from cub hear somewhere I'll look for it and post it for you.
2013 cub cadet GTX 2100 w/IH weights 1984 cub cadet 1282 w/#2 cart, plow, IH weights 1970 IH cub cadet 73 w/fenders Haban 402d sickle bar 1966 IH cub cadet 102x2 1966 IH cub cadet 71 pull start w/Fenders IH sweeper, Brinly Gard N Cart 1965 IH cub cadet 100 w/Fenders hydro lift Brinly Gard N Cart, 3 point sleeve hitch Brinly plow sleeve hitch blade #1 cart 1965 IH cub cadet 70 w/fenders and snow plow 1961 IH Cub Cadet Original #3646 w/fenders 3 point, IH rear blade, non trip snow plow |
I got my fronts of my 72 for a 100$ each from my local IH cub cadet dealer.That was new rim, inner + outter bearings and tire. But on my 71, the tires are still original and in "tip-top" shape even after all these years. So to say you could still find these parts around.
| Thread Tools | |
| Display Modes | |
