Old 07-30-2014, 08:32 AM
rebel715 rebel715 is offline
You mentioned your steering turning a tighter radius to the left than to the right. My cub is the same way. I just made an adjustment to the gearbox and that corrected a lot of the slop. I have not noticed anything loose on the steering, but I will be sure to check it out further.
Thanks.
1977 IH Cub Cadet 1000
Old 07-30-2014, 09:19 AM
Stratmoore Farms Stratmoore Farms is offline
Thanks.
I adjusted the linkage between the steering lever and the arm. On the 104, this is on the left side of the tractor, so shortening the linkage will improve the turning radius to the right.
The nut/bolt that connects the linkage to the arm was loose, causing all of the slop in mine.
Christ died for you, live for Him!!!
Bob
Old 09-14-2014, 12:09 AM
CumminSHO's Avatar
CumminSHO CumminSHO is offline
I have the same issue, so if you adjust the right outer tie rod that will help balance the steering radius?
Old 09-15-2014, 01:48 AM
No, adjust the rod between the lever on the gear box and the arm on the spindle.
Personally , I like the steering to be tighter to the left. The left side of the tractor is used for getting close when mowing, a tighter turning radius makes getting and staying close easier.
Old 09-15-2014, 09:53 AM
CumminSHO's Avatar
Alright, I will give that a try. I understand where you are coming from for when you are mowing around trees you would want that left side closest to the tree, but when it comes to turning around at the end of the lawn it makes for a tough time.
Old 09-15-2014, 09:58 AM
rwairforce rwairforce is offline
More than one of mine is like this. Turns much sharper to the left. I wonder if that's the way they were for the improved trimming. I know it's probably not the case but my 127 and 1440 turn sharper to the left. Oh well, such little things just provide a longer ride when turning to the right.
Randy
Cubs: 71, 72, 127, 149, 1440, 2186 and 1864
John Deere 110 round fender
John Deere 140 H3
Sears: GTV16
