Old 04-30-2010, 12:20 PM
dads70's Avatar
dads70 dads70 is offline
Default Happy to report
got a carb kit which i only needed the needle!!! for 42.00!! once i cleaned the bowl out and put the new needle in it she fired right up once the bowl filled and cut the yard like a champ, since i gave her to my 13yr old son this weekend ill teach him how to mow with her he has already changed her oil and greese it. will get some pics of it and my lil 70 over the weekend and post monday by noon, love these old gals
Old 04-30-2010, 12:32 PM
$42??!!! Where on earth did you buy that? A carb kit costs about $12 from CC, and that's the most expensive I've ever seen them.
Old 04-30-2010, 12:44 PM
Turbo Archie's Avatar
Turbo Archie Turbo Archie is offline
I just paid $28 from NAPA and I only needed the needle.
That fixed my problem.
Old 04-30-2010, 01:03 PM
Oh, and as quickly as today's gas destroys gaskets in carbs, you are better off putting all the parts in the first time, rather than taking if off again when something starts leaking. BTDT.
Old 04-30-2010, 01:07 PM
dads70's Avatar
Default screwed in a way
at the only mower shop in town that had a kit for the walbro carb and i only needed the needle!!!! oh well shes runnin now
Old 04-30-2010, 02:57 PM
Glad you got your 86 going. Looking forward to your pics!
Old 05-02-2010, 02:45 PM
mrcubcadet's Avatar
Default Cub Cadet 126 Carb
I have a similar problem with my 126. When I got it it was leaking gas out of the air bleed but only when it was not running, so I had it rebuilt. got it back on the tractor and it did the same thing . Anyone know what to do?
Thanks
Old 05-02-2010, 03:37 PM
Check the float level and make sure the float isn't full of gas. Also, if you have a bunch of crap in the gas tank and no sediment bowl or filter, the needle won't seal in the seat.
Old 05-02-2010, 05:40 PM
mrcubcadet's Avatar
It has a filter but last time I took it appart it didn't seem that there was anything in the float. I also took a sew driver and bent the float down to make it push the needle more, but once I got it to stop leaking it wouldn't let enough fuel into the bowl and would run a little while and then die.
