I was looking in the tech library on how to test a 15 amp stator. I see that specs are .064 to .096 ohms . Is that bench testing or does it have to be tested while in operation?
Brian April 1979 1200 Quietline 44A deck 1988 1211 customized into a 1288 with a K301AQS 38C deck and a 1864 54” deck . Snow blades 42" and 54" . Brinly disk, brinly plow a cultivator and a $5 brinly yard rake!
Bench testing. I wouldn't suggest touching the leads when it's running. It puts out AC power.
Not to say you can't test the AC output..... just be careful. But, seriously, OHM checking is for when it's off. Also, the test in the library specifically says "static test" which means, "not running". |
That's why I asked, thanks Jonathan !
No problem Brian!
Yes, your meter will get mad at you when you do that and might make you change it's fuse
Page 8.14 of the "Kohler Single Cylinder service manual" does a very god job of describing how to troubleshoot and test a 15 amp battery charging system.
| Thread Tools | |
| Display Modes | |
