ok this thread is gonna take a while but here goes
got the 2082 tore down for sand and paint... not a fan of the rockshafts and brake shafts have one i couldnt get out at all are these powder coated? the sander dont like it
982D kwik-way loader w/3 spool control and front and rear remotes,2182, 1812 cat 0, 1440 puller, 3185 grass killer, 2x 450s, QA42, 364, tiller |
this kinda sucks since the seller said hydro is fine... anyone ever welded one of these? i think ill give it a try if it dont work out i have the one from the 782D. looks like im gonna have to put in another order to extreme. ill post again when i have more pics as the build goes on
thats what i was thinking
spent last two evenings stripping and sandblasting the frame what a b#@%h must be powder coat found spray on chemical stripper that dont work too bad will post pics later
finally got enuff paint off now to blast the flash rust out used stripper in a spray can worked pretty good but took several attempts in some places
Thanks for the pics and update.
Is it a IH 982 (79-81) or a CCC 982 (82-85) ? This is a rare and nice bird, founding implements for it most be a PITA. Of all CC this is the one I wish I own brand new and an original of course :-)
Looking forward to see the progress you did on that gem, keep the good work
Gilles. 1988 2072 401 54" hyd angled blade 1988 1872 364 snowblower/C50 deck 1976 1650/QA42A blower/44A deck/standby 1976 1450TS/Sleeve hitch/44A deck/in storage 1963 100 (red)/in storage 2010 Kubota 2380-2/42" infinity deck (engine swap) |
This thread tittle is confusing but the mistake is mine since you clearly specify stripping a 2082 frame in your first post. It's a interesting build to follow and a unique bird repro.
I wonder what diesel engine ICC or CCC may have swap in the 982 if they had build one? What was available between 79 to 86? I bet they fit at less a 16 to 20hp if they could.
| Thread Tools | |
| Display Modes | |
