Old 05-05-2014, 12:46 AM
OffTime's Avatar
OffTime OffTime is offline
Default PTO release button/bearing
I mentioned a week ago or so that I have a full cage ball thrust bearing in my 129 as a PTO clutch release bearing. Several of you expressed interest in seeing some pics and so forth. [IMG][/IMG][IMG][/IMG][IMG][/IMG][IMG][/IMG]
I realize the pics are a little unclear. The bearing OD is 13/16" or .8125". ID is 1/4" or .250". the thickness is 5/16" or .3125". I didn't do it, but I would think that an Amazon search would come up with such a bearing for not too much money. It is the same type of bearing used on the "Steering Upgrades" on the Ross steering gears that use a "Nice 605" bearing only it is smaller.
Since I didn't do the conversion, I'm not really sure how the little pin that the bearing rides on is held in place in the center of the clutch. All I know is that it works great. Every time I grease the machine, I undo the clutch linkage, remove the bearing, and add a touch of grease into the balls. Any questions please ask.
P.S. Don't look at the paint (or lack thereof) or the wiring to the lights. I have all the wiring supplies to completely redo the wiring harness and someday (when I get really ambitious) The thing is going to get stripped down to every individual piece and it's going to get painted.
Matthew B
1972 129 w/hydraulic lift and head light option soon to be repainted
Old 05-05-2014, 08:51 AM
DoubleO7's Avatar
DoubleO7 DoubleO7 is offline
I am confused.
Do wide frame PTO's have a center button with a stud sticking out?
I have only dealt with NF,s which have a convex head center button on the PTO.
Old 05-05-2014, 10:57 AM
Originally Posted by DoubleO7 View Post
I am confused.
That is a custom made button to hold the bearing.
Offtime,
Are there any numbers on the bearing?
Old 05-05-2014, 03:35 PM
OffTime's Avatar
Offtime,
No number legible on the bearing. If I can find some time, I might can try to research the number and let you know. I think I have some resources.
Matthew B
Old 05-05-2014, 03:44 PM
OffTime's Avatar
I am confused.
Double07
Just come on up here and take a good look at it. I'm only about 6 - 7 hours drive from Pensacola. You could take a look at the muffler at the same time. Lol.
Matthew B
