Old 05-03-2014, 08:56 PM
Good to hear you got it off!
Old 05-03-2014, 09:27 PM
Looking good, Sam!
Originally Posted by ford4150 View Post
I got mine off today without damaging anything! I don't have photos, so I'll try to explain. Removed the two bolts holding the control rod support (it's "Z" shaped). Cut a 1-1/2" x 1-1/2" block of wood about 3" long. I C-clamped the control rod support and block of wood to the frame in the same location it normally is bolted. This puts the control lever 1-1/2" above the dash. Room enough to use an 18" pry bar, curved on one end, with a strip of 3/4" thick wood block to protect the dash. I heated the chrome lever with a propane torch just below the set screw hole. Pryed up with the crow bar and it came off. Knowing it has a splined shaft was the key!
Glad you got it!
Old 05-03-2014, 10:14 PM
OffTime's Avatar
OffTime OffTime is offline
I had the same problem on my 129. After much heart ache and trouble to get the lever off, I cross drilled the lever and the shaft and put in a 5/32 or a 3/16 roll pin (I don't remember which). I eliminated the set screw. Works great.
Matthew B
1972 129 w/hydraulic lift and head light option soon to be repainted
Old 05-05-2014, 06:53 AM
steved steved is offline
Thanks for everyone's help. I got my handle off this weekend. I had a friend hold the handle and pull with one hand and with the other hand held a block of wood over the center of the handle. I used the air chisel on the wood twice and the handle came flying off. No damage to the handle.
Old 05-05-2014, 11:24 AM
Great news!
