Old 04-09-2014, 03:58 PM
Tunames Tunames is offline
Default Look what the PO left me!
The flange held to the trans input with a cotter pin ! As far as I can find it should be a 1/8 x 1-3/4 roll pin? This is on my 2072.
Old 04-09-2014, 04:11 PM
Cub Cadet 915-3004 Pin, Spirol Spring, 1/8 Dia X 1.25 Lg
I've seen worse, like a nail. Check and make sure that the drive arm is not sloppy on the pump shaft.
Old 04-09-2014, 05:01 PM
DoubleO7's Avatar
DoubleO7 DoubleO7 is offline
I guess you can say it was not used hard after the cotter pin install.
Old 04-09-2014, 06:16 PM
Yeah, see all kinds of PO things that make you scratch your head.
Old 04-09-2014, 09:35 PM
cubby102's Avatar
cubby102 cubby102 is offline
Better then the bailing wire that as in my old 125
Old 04-09-2014, 09:45 PM
PaulS's Avatar
PaulS PaulS is offline
IMHO it is not quite as bad as it seems. The tranny is not driven by a 1/8 spirol pin. Both the drive shaft attachment and the shaft coming out of the tranny are splined so the spirol pin holds the drive shaft attachment in place. There should not be much torque on the pin. If so that pin would be much heavier.
Old 04-09-2014, 11:31 PM
It's amazing what PO's do to cubs.
