Old 03-12-2014, 01:48 PM
kycub kycub is offline
Default cub 86 ?'s
I have a model 86 that I just replaced the teaser spring, Throw Out bearing, and clutch disc on. I may still need to adjust the clutch linkage, but I noticed after getting everything back together that the entire throw out bearing looks to be turning against the hinged plate. I noticed some sparks, and the bearing getting hot. I'm not sure if this will wear away eventually, or if something isn't right. The clutch engages and dis-engages like it should. any help is appreciated.
Old 03-12-2014, 04:26 PM
Something is wrong. Look in the tech section for the manual and take a look or post some pics of what you have.
Old 03-12-2014, 05:24 PM
Definitely post some pics of what you got.
Old 03-12-2014, 06:14 PM
Should have about a 1/4" of space or less between bearing and lever. Adjust clutch per the manual.
Old 03-13-2014, 01:54 PM
I think I may have found my problem. When I compared it to my 128, I noticed the 86 was missing a spacer, that on the 128, the teaser spring lays inside it, and the spacer is between the clutch rod, and the rear clutch disc plate. My 86 now has a 10hp in place of the factory 8hp, and could explain why this spacer was gone and why I now need one???
Old 03-13-2014, 03:55 PM
Ok, after some net surfing, I found in missing a 911-3040 spring spacer. Now finding one...
