The choke cable on my 800 was getting "sticky", so I sprayed some PB Blaster down the cable just behind the knob and worked the cable a few times.
Followed that with some silicone spray. Had to use that little straw that comes with the PB Blaster to get the stuff down inside the cable assembly.
Only thing better than having a Cub Cadet is USING one ![]() ![]() |
![]() Quote:
-Ryan
If the cable has the plastic coating, they make a special tool that you hook the spray tube to and work the cable as you spray. They work very well. If it still has the exposed metal coils, then spraying all over while working the handle works best.
Thread Tools | |
Display Modes | |
