Old 08-28-2013, 09:39 PM
Cub-N-It's Avatar
Cub-N-It Cub-N-It is offline
Default CC106 Replaced Clutch, Still Have Problem
Hello Everybody. Things have been going well with the 1650, but now I have added a 1969 Cub Cadet 106 to the LAGT collection. It was a one owner, well used but garage kept. I've got the 10hp Kohler running nicely, also the starter generator works as it should. The problem begins here; The small spring behind the release bearing was broken in three pieces. I replaced it and the clutch disc, but am still experiencing something slippiing with the clutch fully disengaged. I can push the clutch about halfway in and the tractor resumes motion again. I have adjusted it each way with no success.
I really need some guidance here ya'll. This is my first LAGT with this type of clutch system. My CC 1650 is a hydro, my JD 140 is a hydro, all my gear driven Wheel Horses use a belt instead of a clutch disc and pressure plate, and the other Wheel Horse is a hydro. I'm a little out of my comfort zone working on this 106. Where should I look next? and next? Thank you in advance.
Van
Old 08-29-2013, 07:53 AM
Sam Mac Sam Mac is online now
Congrats on the 106. Check the manuals for how to adjust the clutch. This cured my clutch issues on my 121. Everything that came with it was junk anyway. Mid West Super Cub.
Old 08-29-2013, 08:30 AM
Cub-N-It's Avatar
Thank you Sam. I would not be surprised to have to replce the unit you are showing in the pic above. After reading of some related problems others have posted about here, I suspect there may be a problem with the spiral pins (broken perhaps) where they pin the driveshaft to the transmission. I noticed the coupling between the driveshaft and transmission input shaft is running hot to the touch, however the driveshaft and transmission case is not.
Do you have any comments on that?
Van
Old 08-29-2013, 07:51 PM
IH Cub Cadet IH Cub Cadet is offline
Van,
I believe the small spring you replaced is called a teaser spring and it's purpose is to keep the clutch from being "grabby" if that's a word when you let out on the clutch. My 126 clutch slips some and I think I need a new clutch disk and the pressure plate dressed.
BTW - welcome to the zig zag club...
Bill
IH Cub Cadet 109
IH Cub Cadet 126 (2)
IH Cub Cadet 149
IH Cub Cadet 1650
MTD Cub Cadet LTX1042
Old 08-30-2013, 08:29 AM
mickb72 mickb72 is offline
Default clutch
Hello, I think your setup is wrong. That small spring(teaser) should be in front of the realease bearing. Mike
Old 08-30-2013, 08:55 AM
Maple Cabin's Avatar
Maple Cabin Maple Cabin is offline
Need pic's of the clutch setup. Both paddle up and down.
Doug
126 Creeper,H lift,Deck, Sleeve hitch, B Plow, Weights
129 Deck, Blade, Weights
1200 Creeper Deck: 1250 B Tiller odd deck
782R with power steering
JD 110H:JD 112H
Old 08-30-2013, 10:04 AM
PaulS's Avatar
PaulS PaulS is offline
According to my 102 manual here is the order of parts. Starting at the end facing the engine you should have the pinned pressure plate, then the clutch disk, the pressure plate with the slots for the pin and then the teaser spring. If your setup is not like that it should be.
Old 08-30-2013, 12:36 PM
vartz04 vartz04 is offline
Order a full replacement from Yosemite Sam (member on here). Price is less than what you can buy the parts for and it's already put together.
Most of these clutches are worn out beyond replacing one or 2 parts. Save the headaches and do it all if you can afford the $175-$250.
Cub 104 Refurbed Sprinig of 2013
Aftermarket headlights, 3 point, Brinly Adapter, Spring Assist, 42" IH Blade, 42" Mower Deck, 42" Craftsman Grader Blade, 10" Brinly Plow, 6-12 ags and 22x9.50 turfs
Old 09-03-2013, 06:12 PM
Cub-N-It's Avatar
Thank you guys! Sorry to not be back before now but I took advantage of the labor Day Weekend and left town, the Cub Cadets, the Wheel Horses, and the John Deere for a few days. Thank you all for your responses. As soon as I get caught up from being away I will take some pics and show ya'll what I'm working on.
