Old 08-27-2013, 08:58 PM
Loganvilledude's Avatar
Default Mule drive pulley bearings
While I was cleaning the engine drive on the 122 I wiggled the two pulleys on the mule drive. One of them felt pretty tight and the other one is a little loose. I figured I may as well pull it out and see what it would take to replace the bearings. It appears the assembly is two shells that are riveted together so I can't tap the bearings out.
Has anyone changed these out before? It looks simple enough to use the Dremel and cut the rivets off, split it open and get the bearing out / replace and rivet it back together, but I did a quick search on the bearings and nothing came up. So is it even worth it and should I just leave it alone?
Old 08-27-2013, 09:31 PM
rweaver rweaver is offline
those are not fixable to my understanding
Old 08-27-2013, 10:22 PM
gmbadgley gmbadgley is offline
for what they cost they are not worth messing with.
Old 08-27-2013, 10:29 PM
From what I am learning with this ever expanding hobby there are more aftermarket products out there not referenced to the IH /Cub name. I have been researching this board and apparently these are pretty common for many applications. My CCO has cast iron pulleys and the bearings have been purchased and changed, but when I ran into this 122 and searched I came up with nothing until I saw a post you could get them at NAPA.
Thanks for all reply's.
Old 08-27-2013, 10:39 PM
I replaced mine with ones from NAPA. Not only are they inexpensive, the V is deeper than the stock pulley and helps keep the belt in place ( more important with the long tiller belt )
Old 08-28-2013, 07:26 AM
bja105 bja105 is offline
Does anyone have a Napa part number handy?
Thanks
