Old 01-30-2010, 11:47 PM
squatch squatch is offline
Default I hate when that happens!
Just got in from plowing our shared private road. Just 4"-5" of light powder. The 1872 super will move out pushing snow down the road. Unfortunatly I was moving pretty good along the edge of the road when I hit a mound of frozen dirt I had peeled up last time I plowed when it was wet. Just about launched me. Did I mention it's about 16 degrees here right now? That mound of dirt might as well been solid concrete. I shattered the lift arm off the end of my rock shaft. I had to finish plowing with the plow down and no way to lift it. Got it back in the garage and took a look. That pie shaped piece of 3/8" plate steel was hanging by a thread. Guess I know what I'll be doing this week. It's supposed to snow again next week. I think I may remove 2 of the 4 HD springs on that 54" haban plow as it doesn't give much. I'd rather have it flip over a little to easy than not easily enough.
Here is the pics of the lift arm on(or off) the rockshaft.
Before as it should be.
What's left of it.
Where it used to be attached.
Old 01-31-2010, 12:25 AM
jeffb's Avatar
jeffb jeffb is offline
Man...that sucks!! I bent up one of my undercarriage mounts on mine because I forgot to unlock the pin on the plow and it didn't trip when I hit about the same thing! The chains really dug in too , and I doubt that helped any. Good thing I have an extra bracket lying around.
129 , Two 149's , 1450 , 10'' moldboard , single gang disc , Two 1A tillers with extensions , 42'' and 54'' plow blades , and half of a 128!!:biggrin2.gif:
Old 01-31-2010, 06:56 AM
weaverama weaverama is offline
Hey Squatch, how's that dusting of snow we were suppoed to get in Northern Maryland? Whew!
Old 01-31-2010, 07:10 AM
squatch:
I feel your pain. Done that once. Now when that happened, it rivaled a ride at Cedar Point......:biggrin2.gif:
Lucky for me......all that happened was that I bent the Sub Frame. Was fortunate enough to pound it back into shape.
Old 01-31-2010, 04:24 PM
Got a better look today. I thought maybe I had just busted the weld between the arm and the shaft. Ha, see the last picture above. I shattered the end of the shaft. It broke off at a 45 degree angle and is still attached to the arm. Can you say good weld penetration. That's gonna be a PIA to get that stub out. Not much to grab and I'll bet it's rust welded to the rock shaft in the middle of the frame. I'll probably have to drill and tap it and use some pipe sections and big washers as a puller. Pull it out by tightening the bolt I tapped in.
Yeah got a little more than a dusting but it was light and fluffy because it was so cold. It's what's under that snow that bugs me right now!
Old 01-31-2010, 04:35 PM
There must have been a crack near the weld in the end of the rockshaft.
That's not a stub shaft...that goes all the way through the rockshaft to the other side of the frame. Can you remove the fenders and weld the arm back on without disassembling it?
If it's anything like any rockshaft I have dealt with, you will not be able to pull it out by tapping a hole in it and threading in a bolt. The last one I took apart would not budge in a 20-ton hydraulic press, and had to be heated in a fire to free it up.
Old 01-31-2010, 06:47 PM
Thanks Matt, That's what I was afraid of. The parts diagram looks like an inserted stub in each end and then pinned. At least there is a chance of driving it all the way through. No likely way to weld it back up. No crack beforehand. Look at that pic again all clean new meat. I hit that jewel hard. The Haban Plow has a HD frame that goes all the way back. That was the only thing there was to give and I hit on the right side of the plow. My lift rod is a HD tube that doesn't have much flex. Probably hit the end of that arm like a heavy swung 12lb sledge and it was cold out. 16 degrees. The lift arm is only welded on one side(backside) and that side came loose shaft bit and all. I was going downhill at top speed on the super which is probably 12MPH and stopped cold. Actually pitched the tractor sideways. That's Probably what kept me from flying.
Old 02-18-2010, 11:16 PM
Just an update. My used replacement rock shaft arrived today. I got the whole deal with the frame cut away around it. Looks to be in top shape. veruy little wear on the pins. I'm going to drop it off tomorrow at a machine shop. They said they could press it apart for me. If They get it all apart in good shape I can just hack out the old one and install the new one quickly.
Old 02-18-2010, 11:28 PM
murphycc
Guest
Posts: n/a
Soak it in a bucket of water for a couple of days, worked for me.
Here's what a 20 ton press will do even after soaking in water.
Scott
Old 02-19-2010, 08:07 AM
I hope they can get it apart. Like I mentioned in a previous post, the last one I had would not budge in a 20-ton press after being soaked with PB blaster for 6 months. I put it in the wood stove one day, and then I was able to take it apart by hand....couldn't have been easier.
