I got to thinking this morning, when I give my 1050 throttle, the hood starts to rattle against the dash. I was planning on putting some simple vibration damper around the edge but that got me to thinking; is the 1050 a Quietline model that has the ISO engine mount issue? I'm just wondering because I've just practically replaced the entire clutch assembly and I'd hate to have to do it again in a year or so just because I didn't fix an engine mount problem. I will say, however, when I had the engine off, before I put it back on, I replaced the rubber grommets? that went above and below the engine mounts because they looked kinda sickly.
So, is the 1050 a Quietline model I need to worry about fixing the motor mounts for?
-Ryan
Yes and no, it's not a QL but it has pretty much the same engine mounting as a QL. If the mounts are tired I would replace them.
I did replace a couple missing isolation mounts when I did the clutch work and the rest looked good. Kinda makes me wonder if I should look into getting a Quietline mount system that's got the welded bar across it. Are there supposed to be isolation mounts where the motor bolts to the motor mounts? I know there are between the frame and mounts, but what about between the mounts and the motor?
-Ryan
on the 1050 they used 3 styles of engine mounts one had a bracket that had a hole in the side of the frame and it slid into the other was a solid L bracket and the last style was the cradle style and all took their own style of rubber mounts so take a pic and I might be able to help you
![]() The only thing I'm kinda missing is #3, I tried ordering replacements but they aren't available anymore. So what I did was put a #7 in its place. Not a perfect match but better than not putting anything there.
-Ryan
-Ryan
yes those look right and those are fun to get out of the tractor if its the style that slides into the right side frame rail
-Ryan
| Thread Tools | |
| Display Modes | |
