My 86 has decided it doesn't want to play anymore. Since I have got a couple of months ago it has always been hard to start. It would take a couple of minutes of cranking, hitting every once in awhile at full choke then half and then a some black smoke and she was off. Once it was running it wouldn't miss a beat.
Last weekend i started off in too high a gear with a loaded trailer killing it and now it won't start or even hit. I had assumed it was a carb issue but hadn't spent the time investigating yet. Last night I checked plug gap, point gap, tore the carb down cleaned it and set to base spec. The only thing I didn't do was check the timing because I could not find the inspection hole. I can see the points sparking and the plug has good spark when held against the head. After an hour of trying to get something I had gas running out of the muffler and carb throat but very little if any on the plug. I am leaning toward a stuck valve due to the lack of fuel on the plug but the carb has suction if you cover it up and the spark plug hole will blow your finger off and the muffler puffs. Before I tore into it I wanted to see what y'all had to suggest. The only thing I didn't try was putting a little gas in the spark hole to see if it would fire. According to the PO it sat for a couple of years that's why I assumed a carb issue but its clean and looks good to me. It sounds the same while turning over and with the plug out I can't feel anything out of the ordinary while turning by hand. Any suggestions would be appreciated. |
Don't give up the ship!!
![]() Numero uno thing it sounds like to me is a disconnected or defective condenser. You get a pretty spark when the condenser is bad, but, it will not run worth a darn!!
Thanks, ill keep that in mind tonight when I have a chance to get after it again. Unfortunately I don't think I have anything I can swap condensers with to see if that helps.
Well I tinkered a little bit when I got home and managed to lose spark. Going to have to find the battery I stole out of my meter for one of the kids toys......
New points, new condenser and she still won't run. I did manage to get her going for a minute and was trying to tweak the timing when she died again and now I'm back to the same thing: have spark at the points, plug and a blinking timing light I positive side of coil, steady light on negative side, enough fuel to drip out of the muffler after spinning over awhile. I'm stumped. I centered the S on the flywheel and set the points to .020 and can't even get a sputter. What am I missing?
| Thread Tools | |
| Display Modes | |
