Old 04-21-2013, 10:02 PM
scgtguy's Avatar
scgtguy scgtguy is offline
Default CC 1450 hydro coupler roll pin
Hello,
Had a roll pin snap late this afternoon . Its the pin that at the rear of the drive shaft that holds the coupler to the hydro unit. What size is this ? ... can I get one locally ... or is this a Cub Cadet part I should send off for ?
tks for any info
Bryan
Old 04-21-2013, 10:08 PM
macman81's Avatar
macman81 macman81 is offline
it should be just a standard 1/4 spiral roll pin. heavier the better. might want to check everything out and see WHY it snapped?
John,
PROUD OWNER
Cub Cadet 122, 149, 1650 dual hyd and COZY CAB, 782 dual hyd, 54" power angle blade, qa42a snow thrower, #1 tiller w/extensions, brinly plow,
1940 farmall H, Little Wonder 2 bottom plow, 1954 IH Fridge, 1948 IH 158 chest freezer.
Old 04-21-2013, 10:10 PM
brad.bristle99's Avatar
brad.bristle99 brad.bristle99 is offline
Just get a grade eight bolt and double nut it. So much easier.
Old 04-21-2013, 10:22 PM
scgtguy's Avatar
Default Roll pin
thanks you guys ... I'll remove the shaft and take a look. The motor runs fine..when I remove the shaft i'll spin the input of the hydro and feel if seems normal. I was going from reverse to forward when it happened. Everything is dry etc .... and the Coupler holes don't appear out of round or any noticeable cracks etc. When I put the tractor back together I used the pin I took out...the original I suppose.
I'll check it out tomorrow night.
later, B.
Old 04-21-2013, 10:26 PM
dale c. dale c. is offline
i don't reccomend using a bolt it will not be tight in the hole and will egg the hole out in the shaft
Old 04-22-2013, 12:59 AM
I don't think there are very many other people here who would reccomend using a bolt either...
Put a good quality 1/4" spiral pin back in there and providing nothing is wrong with the hydro trans, you should be good for a long long time.
Old 04-22-2013, 09:28 AM
Any good farm implement store, especially a Case IH dealer worth their salt will have SPIROL pins in stock.
Dave S.
Old 04-22-2013, 10:43 AM
sawdustdad's Avatar
Dave S.
Now I get it. SPIROL is a brand name of spiral pin.
Old 04-22-2013, 01:27 PM
scgtguy's Avatar
Cool 1450
Here is the real culprit .... when it let loose it sheared the pin ... also put a hole in the top of my filter.
Anyone have a rear drive couple they would sell me perhaps ?
Bryan
Old 04-22-2013, 01:32 PM
Duct tape for the filter, JB Weld for the coupling!!
Sorry to hear about the failure!!
