Old 04-01-2013, 05:14 PM
I will when I take it off to paint it. It's no big deal 2 pieces of 2" X 2" 3/8" bar stock with a 1/2" hole in it so that the pin that would normaly hold the rear lift will fit through. One welded on each side of the plate. The plate is 3/8" and it's 6" X 6 1/2" +- I like to keep things simple.
Old 04-01-2013, 05:56 PM
vartz04 vartz04 is offline
Any chance you coulda gotten by with 1/4". I can't pull off 3/8 with my welder but I've done 1/4 before without any major failures just a lot of beveling I'd appreciate the pics when you do take it apart.
Cub 104 Refurbed Sprinig of 2013
Aftermarket headlights, 3 point, Brinly Adapter, Spring Assist, 42" IH Blade, 42" Mower Deck, 42" Craftsman Grader Blade, 10" Brinly Plow, 6-12 ags and 22x9.50 turfs
Old 04-01-2013, 06:38 PM
Probably, I tend to over build stuff. My motto is "If it breaks something more important is coming with it". I'll see if I can pop some pics for you soon so you don't have to wait. It's not a big deal to pull it off, 2 wires and 1 pin.
Old 04-01-2013, 07:43 PM
Just realized after reading the e-mail from Jeff that I had the hitch on upside down so before any of you get on my case I fixed it. Sucks to get old. LOL
Looks good and I'm glad to hear you're happy with your purchase
Old 04-01-2013, 07:48 PM
Jeff you and Aaron are first class! It is nice in today’s world to deal with guys like you that deliver what they promise. Keep up the good work.
Old 04-01-2013, 08:00 PM
Thanks Sam.
I would never make or sell anything I would be hesitant to sign my name to. I make every part as it's for my own use.
Old 04-01-2013, 10:21 PM
Looks great, Sam!
Old 04-02-2013, 12:33 PM
Vartz
Took the winch mount off and got some pics for you. As I said the base is 6.5” wide and 6” high. It’s 3/8” plate drilled and tapped for 3/8” bolts to attach the winch. It just pins on at the same place that the factory lift would.
I also flipped the winch around for a better angle on the cable while I was at it.
Old 04-02-2013, 01:12 PM
That is nice, Sam!
Old 07-02-2013, 08:26 AM
It's been a while since I did anything on this project. Got it torn apart yesterday for paint and a few little details. Rebuilt the steering box. Fixed a couple pin holes in the shifter cover with some JB weld. Need to do a little Bondo work on the tower, sand blast the hood and then get some red paint on the old girl. I will probably replace a couple gaskets on the Mag 12 where it is dribbling while it's out because this one is a PITA to pull because of the deep sump the engine has to come out vertically.
