#121
There's always one odd ball or two in this case!
#122
Pic with the winch stuck on the back.
#123
#124
I'm kinda liking that winch idea... Hmmmmm does it seem to be able to take constant hard use? 60 bucks is a good deal if it will hold up.
LOOKING GOOD! ps...I love the seat bracket!! |
#125
No idea how it will hold up. This is not the finished product by any means. Just a mock up at this point. Think I want the winch mounted a bit higher and forward. Plan on running 2 part line on it to slow it down and double the lift power.
I knew you would like the ultra high tech seat support, LOL. It is cushy.
#126
Got the winch mounted today. I decided that using the bagger plate to mount it on was going to cause too many problems so instead I fabed up a mount out of 3/8” plate, drilled and tapped it for the bolts, welded a couple ears on it that allow it to be attached to the tractor at the same point as the lift would attach. Also cut a link of chain into a U drilled two holes pressed the U into them and welded it on the back side for a hookup point under the winch so that I can run a block for 2 part line. I think this is going to work out very nicely. Gotta order a lower hitch bracket. I like the looks of the one that Xtreme has that bolts to both the rear cover and the axle. Jeff in PA is building me one of his hitches so we should be all good shortly.
#127
I do not know how many "lays" of cable are on your winch (no, not wench!!
), but, if there are only 2 lays, the cable will feed out and in at a slower speed, as compared to four. Slower speed will give finer control of the lift.The less cable, the more "gear reduction". It might be worth removing some cable to get the finer control, especially for a plow.
#128
I know that. At the moment it's the way it came out of the box. I may replace the cable with a much shorter one so that I would be working on the first layer. I've wroked with cranes enough to know how they work. But thanks for the comment.
#129
Looking good, Sam!
#130
Looks good Sam!
| Thread Tools | |
| Display Modes | |
