Old 12-27-2012, 10:34 AM
MrGitrdone41's Avatar
Originally Posted by cmatthew View Post
is the "B" on the piston original piston. i didnt see any other numbers yet. still have to finish cleaning it off
I have never seen a B on any of the kohler i have built. Could you get a good pic of it?
1988 1812,dual ports
1973 108
1968 125
Old 12-27-2012, 09:08 PM
cmatthew's Avatar
cmatthew cmatthew is offline
head is also stamped with a B same as piston. the pic at the end is my favorite cause i was just unloading it at home after a mile xmas parade the night before. thank goodness it didnt happen then. cc123 was leading the stampede.
CC 123
402c Sickle Bar, 48" Mower Deck
QA42A Snow Thrower, 42'' Push Blade
IH Back Blade and Rake
Brinly Seeder/Aerator
Brinly Lawn Rake
Brinly 10" Moldboard,Brinly Cultivator, Brinly Disc
Old 12-27-2012, 09:18 PM
cmatthew's Avatar
hang on its coming up...
CC 123
Brinly Lawn Rake
Old 12-27-2012, 09:22 PM
cmatthew's Avatar
measurements of bore from top to bottom one way then the other.
3.374-3.372-3.370
3.373-3.374-3.373
top mid bottom
crank- 1.499 and 1.498
the manual says everything should be in good specs. right?
CC 123
Brinly Lawn Rake
Old 12-29-2012, 07:08 PM
cmatthew's Avatar
i see in the manual it talks about a type C and D piston but no B.??
got new gaskets made for the oil pan and valve cover. lapped the valves. cleaned things up a bit and welded the infamous crack in the frame over the front axle. just waiting on piston, rod, and rings. sorry, i forgot to take pics!!
what is the little cover on the block to the right of the points and cam cover. about the size of a fifty cent piece. its a window to the cam shaft centered over a lobe????
CC 123
Brinly Lawn Rake
Old 12-29-2012, 09:57 PM
Merk Merk is offline
by cmatthew
3.374-3.372-3.370
3.373-3.374-3.373
top mid bottom
This information is from a Kohler service manual.
Cylinder Bore:
New cylinder bore is 3.3755/3.3745
Maximum cylinder wear is 3.378
Maximum out of round is .003
Maximum taper is .002
Crankshaft: (crankpin should be check in 6 places)
Crankpin diameter new is 1.500/1.4995
Maximum wear limit is 1.4990
Maximum out of round is .0005
Maximum taper is .001
Is the engine a K301?
What gages did you use to measure cylinder?
If the engine is a K301 the measurements should be the same or more than the new engine specs.
There is .004 difference in your cylinder bore measurements. That tells me the cylinder needs bored at least .010.
Minimum crankpin diameter is 1.4990. One of your crankpin measurements is 1.498. The crankpin needs undersize .010.
The picture of your piston indicates the piston is burnt in the exhaust valve area.
The picture of connecting rod (Inside diameter where the crankshaft and connecting rod meet has a shinny area in the middle. I would like to see a picture of the crankpin journal.
If I was rebuilding this engine I would do or recomend the following:
1. Bore engine at least .010.
2. Undersize crankpin .010 and a use connecting rod for a .010 under crank.
3. New governor (if yours is plastic)
4. New head bolts.
5. New bearing plate bolts.
6. New push rod pin (old one is usually aluminum-can be mushroom out)
7. Check valve guides-replace as needed.
8. Check head for flatness-rework as needed.
9. Check the top of the block for flatness-rework as needed.
This engine/Cub Cadet lasted roughly 45 years with no internal work done to the engine. You will be better off in the long run rebuilding the engine the right way. Some will say you can get by just reringing the engine. That may last a few years before it starts smoking again or worse yet rod flys apart.
It's your Cub Cadet...your choice
Project Uncle Dick
Cub Cadet 70
Old 12-30-2012, 12:02 AM
cmatthew's Avatar
thanx for the info merk. i used to measure with bore gauges and digital caliper. some day in the near future i plan to do a full restore on her. she is the only tractor i have at the moment. she doesnt have a lot of down time to do it now at least until i get another tractor to fill in for a while. when the cc123 is down for the restore.
CC 123
Brinly Lawn Rake
Old 12-30-2012, 02:33 PM
The crank will need turned.
1973 108
1968 125
Old 01-01-2013, 09:03 PM
cmatthew's Avatar
putting her back together and fire it up. started just fine. burned the oil out from assembly. ran her for a bit with varying rpms just sittin in the garage. a little seeping and some air bubbles coming from around new head gasket. once she is cooled down all the way i will retorque head bolts. shouldnt be bubblin any more then. next time i fire her up i will take it for a little spin and then change oil. check head bolts again. then i will start to load her up with snow removal. and hope she stays together.
CC 123
Brinly Lawn Rake
Old 01-01-2013, 09:06 PM
cmatthew's Avatar
she has got new boots up front now too. v61's. 5 ribs
CC 123
Brinly Lawn Rake
