Old 10-07-2012, 08:21 AM
WOW Great find.
And just in time for fall leaf cleanup
Lew, you are truly the Grand Wizard of pickin' up tractors
Originally Posted by cub1450 View Post
What Diz said!
So true! Great score Lew!
Old 10-07-2012, 09:14 AM
johncub7172's Avatar
Amazing! That lil' Briggs motor is a good one! I just replaced the diaphram in the carb. There was no return from the pump part. Mine had a sponge in the gas tank. That desolved and totaly plugged up the carb. Nice set up find!
Old 10-07-2012, 11:36 AM
red56turbo's Avatar
Lew,
When I first read the title, I thought you had found the mother lode and picked up 70 CC's at once.
Nice pickup on the 70. She looks to be in great shape. Boy, I'm jealous again..................
Josh
Diesel Cub Cadets...........
Old 10-07-2012, 11:39 AM
Thanks guy's.
I do have to rebuild the carb as the leaves are falling and it needs to get running,after that I'll prolly sell it when Im done using it.
Up to 530 and counting...
Old 10-07-2012, 03:37 PM
CaptMax's Avatar
CaptMax CaptMax is offline
Lew, It is good to see someone pursue these with the passion you do. It is only fitting that you should find what others can't. I hope you inspire others to get out there and look, there are always diamonds in the rough. Yours looks to be in great shape too.
CaptMax
Old 10-07-2012, 11:03 PM
Donovan M.'s Avatar
I want a 70 so i can have twins, the 100R and the 70R
Donovan:
62' Original-fenders
Old 11-28-2012, 08:29 PM
Here is an update.
Last week I pulled the motor on the EZ rake as it was leaking oil.I found out that the block is cracked in 3 places on the pto side,no weld can fix it as it is where the cam cover bolts are.
Today I got it running after replacing the cracked head,put a new gasket and new bolts on it,it did not need the carb cleaned. A tank cleaning is in order though.
Old 11-28-2012, 09:03 PM
Darrell Darrell is offline
Lew , When you say cam cover bolts , i think you are talking about the complete side cover on the engine. If that is the case , you can use another side cover from a different engine , OR , JB Weld will work the easiest.
We used it all the time on the 5HP Briggs we put in our race Karts. We tried to save all those old motors that we could , they made more power.
And the JB Weld will be fine , we turned our motors at 7500 rpm's all the time.
If it is cracked where the crank and seal goes , better start looking for another side cover.
Old 11-28-2012, 09:09 PM
The cracks are on the block but migrate where the side cover meets in 3 places.Will give it a try.. thanx
