Hi everyone,
Glad to be apart of the forums, this site has already helped me out a bunch! Anyways I thought I'd share some pictures of my 1200 and what I've done with it. It all started when I found out about a 1200 about an hour south of me for $300. Came with a snow blow and 2 nice size cutting decks, so I decided to jump on it. Also had a very leaky carb, flat tire, and reverse and 1st gear not working, which the seller forgot to mention but I still took it home. ![]() ![]() The front left tire was flat, and instead of getting a tube I got a new tread. Wrestled trying to get the seized wheel off the hub for a day, decided to change it while it was on the tractor which got the job done. From there I got a bottle of engine degreaser went to town with a wire brush. Continued on to sanding while I waiting for the carb kit to come in the mail. Hooked up the plow because it was easy and I wanted to check it out. ![]() ![]() After more sanding, cleaning, taping, priming, painting, and waiting for the carb kit to come... ![]() ![]() ![]() ![]() Continued on to the rims... ![]() Carb kit came in after that, got it rebuilt and tuned up. Took it for a test drive and man was that third gear faster than I expected! Seeing as I want to use the snowplow this winter, it was time to fix the reverse and first gear problem. Currently located a new transxle and today I split the tractor. Going to re-paint all the yellow parts as well now that I can get into them. ![]() Thanks for checking out my tractor everyone! Love my cub cadet already! |
Looks Great !
If you want to get the decals Maple Hunter can hook you up with a set.
Jed Proud to be a FFA member Westmoreland,TN Chapter 1978 Cub cadet 1450 IH Hubcaps 1975 1650SGT Work In Progress 1974 cub cadet 129 with sleeve hitch/spring assist 1974 108 (Mint) #510358 brinly 12 in plow,disc,8 in plow ,2 42, 2 44A ,50A DECKS #40 boxblade,can`t keep up with the rest lol ![]() ![]() ![]()
![]() Your off to a great start!
Looks good!
Adam Current Workhorses: 1977 1650, Sleeve hitch, #2 tiller; 1985 782, QA 42A snowblower, 50'' deck, 42'' blade, Ags, IH Wheel weights; 197? 1250; 1976 1250, hydraulic lift, 44'' deck, 54'' blade (currently needing a engine) Current Projects: 1970 107, Sleeve hitch, 42'' deck, Tri Ribs, 8'' Brinley Plow Family owns over 30 tractors, 7 combines, 2 bulldozers, 2 mid size trucks, 1 semi, too many truck and scouts to count including parts, and 3 pulling tractors. All vintage IH. |
Great thread! Love how its all coming together! IH cub cadets are the best you can get and the most reliable, toughest things out there! Keep up the good work and welcome
1967 IH Cub Cadet 123 1978 IH Cub Cadet 1650 19?? IH Cub Cadet 682 |
Very nice work! Thanks for the pics and please keep the updates coming.
Congrats on the 1250!
You are moving right along!
You are flying through the 1200. Congrats! Won't be long and the white stuff will be flying around. Can't wait to see the finished product!
Josh Diesel Cub Cadets........... |
I actually am looking for a decal set! If he can beat $45, I think we can make a deal. I will try to find him and send him a message, thank you!
Tractor looks good.
If you need the tin work that covers the muffler I have a set off my 1210 that should fit. Can't use it on the 71 that the engine is going into. PM me if you want it. Pics are of the engine when it was sitting on my work bench.
| Thread Tools | |
| Display Modes | |
