Old 10-04-2012, 09:36 AM
TheIHMan's Avatar
TheIHMan TheIHMan is offline
We use a Interstate battery on our 782D. I think it is 425 CCA.
Old 10-14-2012, 09:41 PM
First off, DO NOT use ether on a Kubota engine! Make a habit out of that, and you'll crack the head.
The glow plugs are what makes the ammeter peg to the discharge side. If you have 12V at the solenoid with the key in the start position the solenoid is bad. Can you hear the solenoid clicking when you turn the key to start?
Be careful- I had the starter go bad on my 782D, and something in the solenoid was malfunctioning and causing it to draw a lot of current, which fried the keyswitch.
Old 10-15-2012, 09:10 PM
mrcubcadet's Avatar
Originally Posted by Red Paint View Post
There is no power TO the solenoid whatsoever.
When I turn it back into the warming position, there is very little draw on the ammeter. When I turn it to the start position, the ammeter is pegged on the discharge side, but nothing happens. I can hear nothing clicking no matter which way I turn it.
Not a chance the cables are on backward?
Bad ammeter?
-105___ Tiller
Old 10-20-2012, 11:51 PM
That's a old sleeve hitch plow not a cat 0 plow. You can't use a sleeve hitch with a smoker due to the gas tank in the way. I wonder why they welded that plate there for.
Place a want ad in the wanted section of the site with the required info or contact one of our great site sponsors at the top of every page.
Old 10-28-2012, 11:27 PM
Glad you got your cub running!
Old 10-30-2012, 09:43 AM
jrarick jrarick is offline
How did you get the hood to close on the 51 battery? It is way too tall for my 1772--the hood hits the posts. thanks
Old 10-30-2012, 10:57 AM
red56turbo's Avatar
Did ya get a spark show??
On the hood of my 1772, there are a couple bare metal spots where the battery posts hit the hood and grounded out.
Josh
Diesel Cub Cadets...........
Old 10-30-2012, 04:58 PM
I measured the clearance before I purchased a battery so I never used the 51.
The best(highest amp) I have found that would fit is the Interstate 340. If anyone has found a higher amp that fits it would be helpful to know-thanks
Old 11-18-2012, 08:37 AM
You are coming along great Red Paint!
Old 11-18-2012, 10:25 AM
Thanks for the pics and update!
