Old 09-02-2012, 11:33 PM
wj-ihc's Avatar
wj-ihc wj-ihc is offline
Default Charging Rate
I had been having an issue with my 126 overcharging. As soon as you'd open up the throttle it would peg the needle an never back off. I had took the cover off the regulator and made sure the contacts were not stuck and cleaned them up with a point file. Upon inspection with it running I came to the conclusion the the contacts were not releasing/engaging as they should. So I bought a couple new regulators from my local mower shop (They are stens, with the gen terminal located on the underside). I installed a regulator on the 126 tonight and I think it is regulating better, but honestly I dont have a good reference as to how the amp meter should work. When I first start it up it will move about halfway on the positive side, then when I open it up it will pretty well peg the needle and stay there until it gets back to a full idle. I guess my question is whether it is typical for it to fully charge all the time when above a idle or should it vary more? It has a brand new battery and I have check the generator by jumping the field lug on the generator and it loads the engine as it should.
As for the second regulator I purchased, I put it on my 108 that has not been keeping my (new) battery charged. After a few times of mowing, the battery will no longer crank the engine, just like prior to installing the regulator. The wiring is correct and I have verified the generator works. I am hoping that it is a bad wire as the wires are bare in areas. I am planning on running some new wires before I start believing the regulator is a dud. The amp meter on this tractor continously bounces back and forth neg to pos.
Any thoughts?
5x Originals, one with rear PTO, 70, 2x 100's, one w/ creeper,2x 102's, 2x 122 w/creeper and rear pto, 2x 123's, 105, 125 w/ aux hyd,2x 73's, 126, 2x 147, 86, 2x 108's, 129, 2x 149's, 169, 3x 800's, 2x 1100's, 1250, 3x 1650's, 682, 2x 782's, 782D, 982 w/60" Haban, 1872 w/ Haban deck
2 Rear Tillers, 1 Snowblower, #1 cart and 2x #2 cart
IH/Cub Cadet 79C Chipper
526 Front Tine Tiller
Brinly plow, disk, grader blade
Old 09-03-2012, 08:51 AM
GROUNDING....
Voltage Regulators have to be properly grounded before they can work correctly. The mounting foot of the V/R is usually the grounding point. Take a VOM (or DVM) and measure the resistance between:
* V/R foot and the negative battery terminal - should be zero ohms
* V/R foot and the S/G mounting - should have zero ohms.
Old 09-03-2012, 12:14 PM
wj-ihc's Avatar
Checked both tractors this morning, both show 0-.2 ohms at both the batt cable and gen base depeonding on how steady I keep my hand.
Old 09-03-2012, 07:33 PM
Put a VM on the battery and check the battery voltage at idle and WOT.Voltage reading should not be more that 14.5 volts.You may have a bad wire on your harness.
