Old 07-02-2012, 08:09 PM
Grease for the steering gear box. Hy-Tran or SAE 30 for the trans per the service manual. It is a gear trans not a hydro so gear oil won't kill it if that is what you put in it.
Old 07-02-2012, 09:24 PM
cmatthew's Avatar
cmatthew cmatthew is offline
X2 ^^^^^^^
CC 123
402c Sickle Bar, 48" Mower Deck
QA42A Snow Thrower, 42'' Push Blade
IH Back Blade and Rake
Brinly Seeder/Aerator
Brinly Lawn Rake
Brinly 10" Moldboard,Brinly Cultivator, Brinly Disc
Old 07-02-2012, 11:15 PM
mrcubcadet's Avatar
..For some reason I didn't register that this thread was on a 100. Oops!
-105___ Tiller
Old 07-02-2012, 11:19 PM
staylor1650's Avatar
staylor1650 staylor1650 is offline
so i just need to find the grease zerk on the steering box and 90w in the rear end wont hurt anything?
75 Cub Cadet 1650
64 Cub 100
not cub but its yellow 62 allis chalmers b-10
Old 07-02-2012, 11:46 PM
4SPEED's Avatar
4SPEED 4SPEED is offline
if the brake is internal it'll squeek and lock up if gear oil is used.
Doug
Original , 100 , 125 , 582
Old 07-03-2012, 02:24 PM
And the trans will probably be stiff and noisy when cold in the winter since it is designed for thinner oil.
If only to ensure correct function of the brake, I would use the correct fluid.
