Old 05-08-2012, 02:15 PM
Nice job Randy!
Old 05-08-2012, 09:54 PM
dieseldan123's Avatar
Wow! And i thought i restored cubs fast! Did maple hunter make your decals? Nice tractor!
1967 IH Cub Cadet 123
1978 IH Cub Cadet 1650
19?? IH Cub Cadet 682
Old 05-09-2012, 05:53 PM
mrcubcadet's Avatar
Originally Posted by RandyD View Post
This is how my "1600" came out!
Very nice!
Did you leave your clutch stock?
-105___ Tiller
Old 05-09-2012, 06:55 PM
RandyD RandyD is offline
The decals did come from Maple-Hunter. Engine has an 18hp cam,.030" over piston,and a 3 angle valve grind. I used a red Midwest clutch spring set at 5". The other clutch componets are stock , added a creeper and spring assist,sleeve hitch set-up along with a tiller gear box. I did this tractor the hard way by converting a 1650 to a gear drive,adding the lift handle and associated parts. Since I got a few supers it sets in the garage.
Old 05-09-2012, 08:30 PM
ajgross ajgross is offline
Inactive Member
WOW! I would hate to see what that K341 will do to the creeper. Those creepers weren't designed to handle that kind of hp.
Conner let me know how those solid mounts work. I've been curious about them for a while now.
AJ
Old 05-10-2012, 03:39 AM
tgwilie tgwilie is offline
I hope my "148" and "168" look half that good when I finish them. Were the 1600" decals custom made? I called MH about some custom decals for mine and I got a very abrupt "NO".
Old 05-10-2012, 07:24 AM
AJ
CCC used basically the same creeper on the 1606 and 1806, and I've never heard of somebody pulling off a creeper that got torn up, but I'd be more concerned about that spring and the creeper bearing. The load that stiffer clutch spring applies is much higher than the axial load the bearing is designed to handle.
Old 05-10-2012, 10:56 AM
I can not get enough traction to stall a 10HP engine in 1ST gear without a creeper,,,,,,
What would you have to do to get enough traction to worry about the creeper??
Hook it to a weight transfer sled??
I would not worry about the creeper because the tractor will always be traction limited.
I feel the creeper will only be useful to change speeds, not add wheel torque.
The creeper will be great for a snow blower, or a tiller, or my use,
letting the tractor crawl across the lawn in 1ST gear low creeper at an idle by itself as I throw in sticks that fall from the trees each winter.
Old 05-28-2012, 06:52 PM
DMegee's Avatar
DMegee DMegee is offline
So... how did the solid mounts work i was wondering about doing the same thing to my 1000
Old 08-03-2012, 10:30 PM
mrcubcadet's Avatar
Sorry that I just got to reply to your question...
I actually haven't had a chance to get the thing going, yet..But should get time to work on it in the next few weeks.
-105___ Tiller
