hi guys iam stumped when i rev the throittle the ovenor is not working as is it is supose too i have changed the spring and the placement of the spring
thanks thad |
when you said ,you changed the placement ,i don,t get that ,the spring will only go one way ,that will work
where the end that mounts in the governor arm moved it to a more sensitive hole
Governors seem to be a theme lately. If you can't get it lined out, you will probably have to pull the motor and look at replacing the governor components.
![]() Quote:
Thread Tools | |
Display Modes | |
